    I need help!
    I have the g-code .The machine go from point A to point B following the path(the z axes no mater). I want my machine when he reach point B to go back to point A following the path and to repeat that for 6 time.
    OK, so what's the question? What do you need help with and what is the problem?
    I undestand how the machine work.
    Ok
    Point A X0Y0
    Point B X600Y600 to go back to A X0Y0 easy when are only 3 .points..code line easy
    Point A X0Y0
    Between the points are from start to end 43578 points complicate shape
    Point B X600Y600 from hire to go back (from end to start) through all 43578 to Point A
    Like ping-pong move. ...
    Draw it in CAD and use CAM!
    Wal's Avatar
    Lives in Stockport, United Kingdom. Last Activity: 4 Weeks Ago Has been a member for 9-10 years. Has a total post count of 491. Received thanks 71 times, giving thanks to others 29 times.
    Hey man,
    Try this neat little on-line tool:
    https://www.miniwebtool.com/reverse-lines/
    Basically it reverses line order - just pay attention to what you're doing... (ie. canned cycles, G02 commands etc. will throw a spanner in the works - this method will only work point to point..!)
    Wal.
    Thank you Wal ! This is ...
  1. Plasma g code
    By whensparksfly in forum Programmers Corner
    Last Post: 22-05-2016, 06:44 PM
  2. A little bit of G code help please!
    By njhussey in forum Programmers Corner
    Last Post: 16-11-2015, 03:36 PM
  3. Anyone got some 2.5D G-code please ?
    By dudz in forum Programmers Corner
    Last Post: 22-06-2013, 11:21 PM
  4. Cambium Code Web Tools – Parametric G-code Generation
    By CambiumMachines in forum Manufacturer News
    Last Post: 09-01-2013, 04:56 AM
  5. G Code help
    By moose007 in forum Programmers Corner
    Last Post: 22-05-2009, 11:39 AM
