13-06-2018 #1
I am VERY new to the CNC world, and wondered if anyone could offer any advice for the following. I am attempting to cut 1.15mm sheet aluminium which has a white polyester coating on one side, protected by a plastic film, which is used within the world of photography!
To date, I am dry cutting the sheet with the coating face down and getting very mixed results. The biggest issues appear to be that chips are getting between the spoil board and the sheet, which in turn the tool is beginning to lift the sheet causing jagged edges. The edge cut quality is paramount and on part of the cuts it meets the grade, and other parts it doesn't. I have asked a few CNC users that have cut aluminium and of course each has a different answer for RPM/Feed rate etc, but currently I use a 6mm carbide tool @4000RPM with a feedrate of 0.5.
Any advice would be gratefully received in terms of tools / rates / technique!
13-06-2018 #2
13-06-2018 #3
13-06-2018 #4
500mm per minute - correct - is it simply a case of spraying a bit of WD40 on the tool? I was planning to direct an air coolant spray at the tool/cutting surface to try to clear the chips....
13-06-2018 #5
13-06-2018 #6
In terms of Speeds / Feeds, there is variance depending on your machine.
For Aluminium, 2 flute uncoated endmills are good. You did not mention depth or width of cut, or if you are slotting or not. You can try different methods, look up NYC CNC on Youtube, has many videos around Speeds and Feeds. Ideally you want to cut as deep as possible and take 10-15% of the Width as a cut. If you cant (because you are slotting), then Id probably go around at 1mm DOC at the speeds / feeds you mention. If you can vary your feeds during the cut, you will see and hear when the machine seems happiest.
Just keep the chips clear and some lube on the cutter. No need to overkill it.
You can see here, same size endmill, but loads more RPM and a sturdy machine = 4000 mm/min cutting, but lots (probably too much) lube.
https://www.youtube.com/watch?v=QAv-q9P4FjA&t=67s
13-06-2018 #7
How is your sheet held down apart from clamps at the edges?
Are you using vacuum or tape to hold down areas away from the edges?
Try a single flute cutter with air to remove chips and lube to reduce chip welding to the cutter, 4k rpm sounds a bit low for ally sheet, what speed/feed calculator are you using?You think that's too expensive? You're not a Model Engineer are you? :D
NEW MEMBER: New to CAD, looking for help in getting started cutting CF sheet
By Devil_WAH in forum New Member IntroductionsReplies: 2Last Post: 23-02-2017, 07:30 PM -
Water bath for cutting Carbon fiber sheet
By Kendrick57 in forum Machine Frames & BedsReplies: 1Last Post: 25-02-2015, 09:14 PM -
cutting and engraving sheet alu and copper with cnc router
By chris in forum Metalwork DiscussionReplies: 2Last Post: 21-02-2014, 10:55 AM -
RFQ: Composite flat sheet cutting. (Water jet or router)
By carboncactus in forum Projects, Jobs & RequestsReplies: 0Last Post: 05-08-2013, 08:31 PM -
Need to cut .5 Aluminium Sheet - Set-up Needed
By Andrew in forum Metal Finishing TechniquesReplies: 15Last Post: 15-08-2010, 04:12 PM
