Stepcraft S420 (~A3 sized) desktop CNC router. Fully set up and working with a PC running Mach3, an upgraded spindle (Kress 800), basic tooling (collet and 1/8" end mill and 3mm drill, all I needed!), and a table with homemade quietening box attached to it.
I believe it’s a version 1 machine but it has the brass rollers as per the version 2. I redrilled the spindle mount plate to allow clearance for the larger Kress 800.
I've used it to cut out and drill 6082-T6 aluminium plates of 1.5-5mm thick to make parts for my microlight Phantom and other aircraft. Its probably as much as can be asked of the machine, it takes ~20mins to cut out a plate in shallow passes. But it produces more accurate and repeatable parts than I managed by hand.
Its a basic beginners machine, a good introduction to CNC machining, good to learn about CNC on as not too expensive or dangerous, and German-made so works fine and has support if there are any problems (stoneycnc.com).
The box hinges on the table to allow full access, and the lid opens separately to allow a quick and easy peek-in whilst in operation.
Reason for selling: its taught me lots about CNC, now I've braved a bigger, more complex machine.
ID:	24451Click image for larger version.
ID:	24449Click image for larger version.
ID:	24448Click image for larger version.
Collection from Windermere, Cumbria.
