29-08-2018 #1
Ralph Waldo Emerson
29-08-2018 #2Current Activity: Viewing Is a 600W AC servo better than a matching asyncrounous single phase AC motor?
Threadlock Blue, you can still take out at a later date.
Phill
29-08-2018 #3
Can you make the washer thicker? If so convert it into a threaded lock ring with a couple of pin holes or some such, to tighten. Should help a bit especially with a drop of thread lock!
29-08-2018 #4
As leadhead, just use a longer bolt and a flanged nut to lock it plus your locktite.
MikeLast edited by mekanik; 29-08-2018 at 09:36 AM.
29-08-2018 #5
I thought of locktite, but at £30 a go and I'll use it once not very economic. I'll be borrowing a bit of the daughters nail polish I think :)
Ralph Waldo Emerson
29-08-2018 #6
Check out the tube for Thread lock. £4/5 would get you there.
29-08-2018 #7
My bad
the idea i posted won't work, what you have to do is lock the two nuts together so instead of the allen screw insert a small length of 6mm all tread tighten the first nut and put another nut onto the all thread and lock that against the first nut.Unfortunately that only stops the nut coming loose so you still need the locktite for keeping the allthread fixed in the shaft.
Regards
MikeLast edited by mekanik; 29-08-2018 at 11:54 AM.
29-08-2018 #8
Ralph Waldo Emerson
Please help me... It wont work.
By kingcreaky in forum Artsoft Mach (3 & 4)Replies: 12Last Post: 22-01-2014, 10:42 PM -
RFQ: Need ideas (or someone to make) a widget to couple motor shaft to M8/M10 threaded rod
By HankMcSpank in forum Projects, Jobs & RequestsReplies: 11Last Post: 17-04-2013, 07:35 PM -
Poorly siemens inverter, wont switch on.
By jonisonvespa in forum Spindles & Drive MotorsReplies: 7Last Post: 06-12-2012, 04:45 PM -
Simple Solution- Drive 1" Ball Screw Shaft with NEMA-23-Size Stepper Motor Shaft
By LoveLearn in forum Gantry/Router Machines & BuildingReplies: 5Last Post: 08-02-2012, 01:52 AM -
Machine bed T bolt
By Colin Barron in forum Gantry/Router Machines & BuildingReplies: 0Last Post: 02-10-2010, 11:20 PM
