    So I have a M6 bolt that fits in a threaded shaft. I want to fix the bolt so it doesn't rotate in either direction when I fit a motor to it. The bolt shaft is flush to the bearing so I cant put a grub screw in.
    Picture attached - any good ideas lads ?
    Ralph Waldo Emerson
    phill05's Avatar
    Lives in Derbyshire  UK, United Kingdom. Last Activity: 13 Hours Ago Has been a member for 9-10 years. Has a total post count of 295. Received thanks 28 times, giving thanks to others 13 times.
    Threadlock Blue, you can still take out at a later date.
    Phill
    Can you make the washer thicker? If so convert it into a threaded lock ring with a couple of pin holes or some such, to tighten. Should help a bit especially with a drop of thread lock!
    As leadhead, just use a longer bolt and a flanged nut to lock it plus your locktite.
    Mike
    I thought of locktite, but at £30 a go and I'll use it once not very economic. I'll be borrowing a bit of the daughters nail polish I think :)
    Ralph Waldo Emerson
    Check out the tube for Thread lock. £4/5 would get you there.
    My bad
    the idea i posted won't work, what you have to do is lock the two nuts together so instead of the allen screw insert a small length of 6mm all tread tighten the first nut and put another nut onto the all thread and lock that against the first nut.Unfortunately that only stops the nut coming loose so you still need the locktite for keeping the allthread fixed in the shaft.
    Regards
    Mike
    My bad
    Regards
    Mike
    Think I'll try this idea with hex sleeve on the bolt against a spring washer or 2. Then test it under load. If that fails LeadHead's green loctite of fleabay for £2.99 will be next :)
    Ralph Waldo Emerson
  1. Please help me... It wont work.
    By kingcreaky in forum Artsoft Mach (3 & 4)
    Last Post: 22-01-2014, 10:42 PM
  2. RFQ: Need ideas (or someone to make) a widget to couple motor shaft to M8/M10 threaded rod
    By HankMcSpank in forum Projects, Jobs & Requests
    Last Post: 17-04-2013, 07:35 PM
  3. Poorly siemens inverter, wont switch on.
    By jonisonvespa in forum Spindles & Drive Motors
    Last Post: 06-12-2012, 04:45 PM
  4. Simple Solution- Drive 1" Ball Screw Shaft with NEMA-23-Size Stepper Motor Shaft
    By LoveLearn in forum Gantry/Router Machines & Building
    Last Post: 08-02-2012, 01:52 AM
  5. Machine bed T bolt
    By Colin Barron in forum Gantry/Router Machines & Building
    Last Post: 02-10-2010, 11:20 PM
