Hello,
I'm trying to wire the AM882 Fault Alarm ALM on my system,
the latch reset and e-stop already works.
The Pilz S5 has 2 inputs, i'was thinking using on input for the limits and one for the am882 alarm, but when one of the 2 input signal is open the relay goes in Fault (red light) and it must be reset by removing the relay supply... 'maybe a problem of setup mode ?
or 2 I could wire the alarm in series on the estop circuit from the 24v to the inputs of the s5 but adding 3 or 4 inductive proximity sensor in series could be a problem with the maximum 100mA on the AM882 alarm.
Do you have an idea ?
Thanks for your help...
27-09-2018 #2
28-09-2018 #3
Have you check this thread?
http://www.mycncuk.com/threads/5566-...eadshine-AM882
05-10-2018 #4
28-04-2019 #5
Hello
I ve still the problem of connecting the am882 alarm with a pilz if you have an idea it can help
I am sorry to hear that, I hope the help come soon!
Wiring up the Alarm output on Leadshine AM882
By Shinobiwan in forum Motor Drivers & ControllersReplies: 42Last Post: 01-08-2017, 02:07 AM -
AM882 Alarm and Enable Signal Question
By Gotty101 in forum Motor Drivers & ControllersReplies: 2Last Post: 24-11-2015, 11:07 PM -
First CNC build - VFD wiring question
By Bez in forum Gantry/Router Machines & BuildingReplies: 15Last Post: 06-03-2015, 10:44 PM -
Pilz Relay info
By manofgresley in forum General ElectronicsReplies: 5Last Post: 08-05-2014, 10:16 PM -
AM882 Alarm Circuit
By Wobblycogs in forum General ElectronicsReplies: 8Last Post: 28-03-2014, 06:06 PM
