    Wish to cut some simple pipe bending rollers with a half round edge grooves 1/8, 3/16, 1/4 etc.
    Programming is simple, but :-
    Tooling :-
    First option is to use >1/8" RNMG insert but of course too small to be practical.
    2nd - Make an HSS form tool with side relief. Possibly on a parting blade. Difficult to get the rad. accurate?
    3rd - Use a 35 deg 04mm rad tool and approach from two sides with R&L/H tool.
    Any advice on good way to CNC these grooves very much appreciated.
    If I understand the task, I'd use a 35 degree insert in a straight holder. SVVCN holder.
    But this would make an interference of 17.5 deg. at each side as the control point tries to interpolate the radius.
    Lives in East Lothian, United Kingdom. Last Activity: 15 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has been a member for 9-10 years. Has a total post count of 2,909. Received thanks 360 times, giving thanks to others 8 times.
    If I understand what you're trying to achieve, I'd probably go for a MDT (Multi-Directional Tool).
    APT do ones that use WDN inserts - https://www.shop-apt.co.uk/external-...serts-apt.html
    You can't hog metal like you can with dedicated tools, but they're ideal for profiles that would otherwise need a change of tool, but material removal/being as fast as possible are not the top priorities.
    Edit - APT also do MGMN style - https://www.shop-apt.co.uk/external-...n-inserts.html which would also work. In fact most grooving tools can be used for light profiling/turning provided the insert is clamped in place.
    Much easier to help if you show us a picture of what you want to do.
    Pippin - Simply an accurate semi circular cut in the side of 40mm dia. bar.
  1. RFQ: RFQ - Aluminium turning - 1 off
    By robhooley167 in forum Projects, Jobs & Requests
    Last Post: 06-12-2015, 12:41 AM
  2. Advice on turning a part
    By charlieuk in forum Metalwork Discussion
    Last Post: 31-08-2014, 10:38 AM
  3. 2 turning ops or more on solidcam?
    By eamo1978 in forum Solidworks
    Last Post: 25-06-2014, 10:57 AM
  4. RFQ: Parts need turning
    By ams in forum Projects, Jobs & Requests
    Last Post: 15-01-2014, 12:27 AM
  5. RFQ: Some turning required please
    By drumsticksplinter in forum Projects, Jobs & Requests
    Last Post: 16-04-2013, 06:15 PM
