    I have a couple of 2mm 4 flute carbide bits I want to re edge. I don't have a jig but I do have diamond disks I could make a centre for to mount in the 4th axis.
    I'm pretty good with 2 flute, ball end and regular drill bits. But 4 flute is a bit tricky. They also have to be a straight edge too apparently for brass. So it leaves a clean cut.
    Bit new to cnc milling/routing.
    2 flute are easy I have a graver sharpener jig that clamps the tool and just run it over the abrasive media or stone. It's the multi flute I struggle with.
    Sent from my F8331 using Tapatalk
    Lives in East Lothian, United Kingdom. Last Activity: 4 Days Ago Forum Superstar, has done so much to help others, they deserve a medal. Has been a member for 9-10 years. Has a total post count of 2,908. Received thanks 360 times, giving thanks to others 8 times.
    Without a jig, it's not worth it. Even with a jig, you're likely to struggle to get the accuracy required to get all the cutting edges even enough to ensure they all cut equally.
    If you are serious, short of building your own home made sharpener (I.e. a Quorn tool & cutter grinder), or buying what will inevitably be a rebuild project in a more industrial cutter grinder, the cheapest option are these - https://www.arceurotrade.co.uk/Catal...rpening-Module
    That is a serious bit of kit... Maybe one day but for now it will have to be new bits.
  1. Which cutting tool on acrylic?
    By piper1 in forum Machine Discussion
    Last Post: 06-07-2017, 11:12 PM
  2. Tips for cutting 1050 aluminium
    By d4cnc in forum Machine Discussion
    Last Post: 11-04-2016, 07:25 AM
  3. Best Tips for Cutting 6082 Aluminium (CNC Lathe)
    By fidia in forum Metal Finishing Techniques
    Last Post: 29-12-2013, 07:09 PM
  4. Cutting forces at the the tool.
    By Spedley in forum Tool & Tooling Technology
    Last Post: 14-07-2013, 12:04 PM
