    Does anybody know how the washers are arranged in the power draw bar. For the Novamill
    not sure about the novamill but all the other machines I have replaced them on have had 3 with dome up, 3 with dome down etc
    Lives in East Lothian, United Kingdom. Last Activity: 20 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has been a member for 9-10 years. Has a total post count of 2,909. Received thanks 360 times, giving thanks to others 8 times.
    I'm sure they're just one each way.
    Just found the parts diagram, and it's 27 washers, mounted alternating ways, with the bottom one sitting cone up/it's wide face against the bottom of the housing.
  4. The Following User Says Thank You to m_c For This Useful Post:
  5. #4
    Thanks. I thought you would know. I have 30 coming in the post. Then I can test it out.
    edit: Also If I remember I put a 4mm thread in the bottom of the draw bar I presume this is to be adjusted for different length of pull studs. Is the adjustment in the manual?
  6. #5
    Ok Belleville washers fitted. Quick vid + pic. https://photos.app.goo.gl/KvMPgAApyS87yns56 Just have to clean it up now.
    Do you have the correct torque settings for the stack of washers. Come to think of it I might have put a finer thread on the draw bar
  7. #6
    There's nothing in the manual about adjustment that I can remember. Probably worth having a search over on the Denford forum, or even asking.
    I'd guess it'll be a case of adjusting the stack up until the tool doesn't release, then back it of a bit. It's not like you need a huge amount of retention power given the spindle motor fitted to a Novamill.
  8. #7
    Thanks, I will do a bit more research
  1. FOR SALE: Denford Novamill
    By Paul Urquhart in forum Items For Sale
    Last Post: 21-01-2019, 11:48 AM
  2. FOR SALE: Denford Novamill
    By m_c in forum Items For Sale
    Last Post: 27-01-2017, 04:41 PM
  3. FOR SALE: Denford Novamill for sale
    By Clive S in forum Items For Sale
    Last Post: 27-01-2017, 12:48 PM
  4. FOR SALE: 2 x Denford Novamill cnc machines + table.
    By Spaniel84 in forum Items For Sale
    Last Post: 21-09-2016, 11:54 AM
  5. FOR SALE: for sale: Denford Novamill
    By Mash Govan in forum Items For Sale
    Last Post: 12-04-2016, 11:18 AM
