27-01-2019 #1
SOLD SOLD SOLD
Hi listing a Denford Compact 1000 CNC router including all software and computer as below. looking for £1800
There is a video of the machine running and cutting here https://youtu.be/81ufnGRKTNM I disabled the guard on the door so I could film it easier (no reflection)
What is included:
Dell 760 PC with a clean install of Win7 Pro, 4gb RAM.
17” monitor
Keyboard
Mouse
USB and power leads
The Compact 1000 comes with the cutter which is fitted
I do not have the collet spanners
6 ‘T’ nuts slotted into the bed.
Denford software included:
VR milling V5 with licence file. This is the machine control software using G-Code. You can import DXF files and use the program to set up the machine paths from 2D drawings then control the machine, or you can open G-Code files generated in QuickCAM Pro (or other software e.g. Fusion 360, or Deskproto).
QuickCAM Pro with licence file. This is the Post processor, you can open STL files from 3D drawings and set up machining paths, post processing into the required G-Code files for VR milling.
QuickCAM 2D Design (2D CAD design software) with licence file.
Specification of the Compact 1000 (copied from the manual available here http://www.denfordata.com/bb/download/file.php?id=1787).
Safety Features:
• Manual operation, totally enclosed, interlocked, safety guard door.
• Emergency stop button.
• Toolpath graphics to verify part programs prior to machining.
Mechanical Details:
• Travel X axis 400mm (15.7”).
• Travel Y axis 240mm (9.05”).
• Travel Z axis 110mm (4.3”).
Dimensions:
• Machine Length 845mm (33”).
• Machine height 675mm (26.5”).
• Machine depth - door closed 750mm (29.5”).
Weights:
• Machine weight 90 KG (198 lb).
Electrical Details:
• Mains supply required:
220/240Volts, 50Hz, 8 Amps.
• Spindle motor: 1.3 kW
• Spindle Speeds: 0 - 23,000RPM.
• Axis stepper motors
Performance:
• Rapid traverse rate up to 5000 mm/min (197 in./min)
• Max Feed traverse rate up to 5000 mm/min (197 in./min)
The Compact 1000 is ideal for cutting a range of resistant materials such as hard and soft wood, plastic, modelling foam, acrylic and prototyping materials
There are a couple of marks in the bed (see photo) from its previous owner, this was used in a school situation for the F1 in schools program. It has been cleaned, all lead screws and travels lubricated and a new filter fitted to the fan.Last edited by HiBob; 26-02-2019 at 11:17 PM.
30-01-2019 #2
Now listed on ebay with a start price of £850 buy it now £1800. https://www.ebay.co.uk/itm/333058705647
What may be the best way to convert my Denford compact router to mach 3?
By suesi34e in forum Denford RoutersReplies: 34Last Post: 28-03-2017, 08:24 AM -
Denford MicroRouter Compact, what to do next?
By paul_m in forum Denford RoutersReplies: 2Last Post: 08-01-2015, 09:51 AM -
Hi guys, how much is a fair price for my nice little Denford CNC Micro Compact?
By suesi34e in forum Marketplace DiscussionReplies: 4Last Post: 08-12-2014, 12:51 PM -
WANTED: emco compact 8 or denford orac tail stock wanted
By dazza in forum Items WantedReplies: 3Last Post: 25-11-2014, 06:09 PM -
eBay: 1500 x 1000 router any use ?
By EddyCurrent in forum Items On eBay UKReplies: 3Last Post: 24-12-2013, 12:18 PM
