Thread: 3D carving errors query
Howdy,
I’m still finding errors in my 3d carvings. Just occasionally as in this rotary carving I have a line or a band which I need to isolate and go back over to correct. Sometimes as in this test example they are so slight I don’t notice till i’ve removed.
The error is always from the z axis and the problem accelerates the higher and faster the elevation changes are, in relation to the distance between peaks and troughs. I can usually resolve the issue by repeating a pass over the area but think its time to understand the main issue and deal with that.
Material: Beech
head height approx 75mm
Finishing pass: 0.5mm taper ballend, 60mm/s, plunge 30mm/s
I’m presuming this is a mechanical electrical problem as I built the machine from scratch and not a gcode issue. I’m also wondering whether I run the machine too fast. Perhaps I need to adjust the velocity and acceleration of of the z axis motor in Mach 3 motor tuning. Perhaps a combination of severe things?
z axis
1:1 ratio. steps per 169-ish, Velocity 5000, Acceleration 500
What i’m sure would be useful would be if machine could slow to accommodate abrupt Z axis changes and speed up over longer curves, similar to deceleration for tight corners on flat material.
Any ideas or suggestions welcome.
Mysterious Z axis errors
By dachopper in forum General ElectronicsReplies: 11Last Post: 01-04-2017, 05:11 AM -
mach3 csmio ips errors
By Web Goblin in forum Artsoft Mach (3 & 4)Replies: 7Last Post: 07-01-2017, 10:47 PM -
Axis scaling errors - is this just to be expected with C7 screws?
By GND in forum Gantry/Router Machines & BuildingReplies: 22Last Post: 23-11-2016, 11:19 PM -
Motorcalc spreadsheet errors
By jimbo_cnc in forum General DiscussionReplies: 7Last Post: 10-03-2015, 07:02 PM -
V bit carving
By Mikeb in forum Tool & Tooling TechnologyReplies: 4Last Post: 20-02-2014, 04:52 PM
