    Hi all,
    I'm adding a spindle to my mill, just for small turning parts etc. I'm using the chinese AASD servo and drive but cannot get it to run correctly on my controller. The controller is a CS Labs IP/A unit.
    It will run ok as long as speed is below say 2900 rpm but if i ask for full speed the controller faults on max following error being exceeded.
    In Pid tuning you can jog the spindle at various speeds and below 2900 rpm the following error is low <100 as you go over that speed the counter just runs away until it faults and stops
    JazzCNC had the same setup here...
    https://youtu.be/tW8knRAOr7s
    and it seems to run ok.
    I also have these motors/drives on all other axes but the big difference is that they never run flat out as i have the motion tuned pretty low. I did take a motor off of another axis and connected it to this drive and it did the same thing so that points to the drive or controller??
    Four pictures below of encoder channel A, at the controller, three at different speeds and one taken direct from the drive output with cable to controller disconnected.
    I have no idea if these are normal or bad??
    Its not a ground loop as the signal does change if i remove the shield connection.
Name:	Drive out copy.png
    Totally baffled.
    Any suggestions?
    Its not encoder related as far as i can see :(
    I had a spare 600ppr encoder so wired that in and connected it by clamping in the spindle.
    It still suffers the same fault, just slower as there are only 2,400 pulses instead of 10,000 per rev - the error count just goes up slower.
    It still worked ok until 2980rpm.
    Lives in East Lothian, United Kingdom. Last Activity: 10 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has been a member for 9-10 years. Has a total post count of 2,910. Received thanks 360 times, giving thanks to others 8 times.
    What's the drives max speed, and analogue input scaling set to?
    I'd guess most drives will default to 3000rpm, and 3000rpm at 10v.
    Exactly that - 3000rpm, 10v.
    300rpm/v
    Lives in Marple Stockport, United Kingdom. Last Activity: 18 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has been a member for 9-10 years. Has a total post count of 3,333. Received thanks 618 times, giving thanks to others 78 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    I am not sure but I don't think the motors will go above 3K
    Yes but i can't even reach 3k when it should??
    A hand-tacho seems to think its doing 3k but the controller error says its not?
    BTW, the motor and drive will do 5k but only 3k for manuf specs ;)
    300rpm/v
    The drive is probably not seeing the full 10v. Try bumping the rpm/v up a bit
    Tried that now, apart from altering either the top speed or the acceleration ramp depending on which way i tweaked the ramp, it made no difference at all - still get the increasing error count above 2990 rpm
    Ok,
    Using my bench PSU it was giving 2965rpm one way and 2971rpm the other.
    It was also creeping with the inputs shorted out.
    I ran the auto zero speed set function which killed most of the creep.
    Then adjusted the gain to 305rpm/V
    It now gives 3000rpm forwards and backwards.
    Did it fix the issue?
    No :(
    A short video of the Pid screen at 2990rpm and 3000rpm
    https://youtu.be/i7GEe7jAoY4
    Motor slip ;-)
    Most servo spindle controllers have a switch-over speed from Positional to Speed between 2000rpm & 3000rpm
  1. Adding 4th axis to stig x2
    By terry1956 in forum General Discussion
    Last Post: 24-08-2018, 01:57 PM
  2. adding high speed spindle
    By jerome in forum Milling Machines, Builds & Conversions
    Last Post: 21-12-2017, 08:19 PM
  3. Replies: 2
  4. Adding earth cable to 2.2Kw Chinese Spindle
    By Dwayne Dibbley in forum Generic Chinese Spindles
    Last Post: 13-03-2013, 04:04 PM
  5. SolidCAM/WRKS troubles
    By 25ncjimmy in forum Solidworks
    Last Post: 11-03-2011, 05:45 PM
