I'm hoping someone can point me in the right direction. I have an axbb which is great btw, I also bought a cheap 5 axis Bob to connect to port 3 to give me more inputs for the control panel. I thought I would use the additional outputs to light the control switches to show their active state and bought a cheap 4 channel opto isolator for the job. The Leds on the optoboard switch on when I activate the output but I can't seem to get the switch lights to work on the output side of the opto? I connected the output side G to -0v(24v) and the output side to the switch bulb with the other side of the bulb to +24v. Is this correct? Also I checked continuity on both grounds on input and output sides and they seem to be connected....is this right?
Cheers for any help you would like to give
Sent from my SM-G920F using Tapatalk
