    This was my yesterday project ---
    and I briefly mentioned it in another thread.
    Doddy - I cut the PCB with a 1mm single flute mill to drill the holes and clear the bulk of the copper, then tidied up the tracks with an engraving cutter, DOC 0.2mm.
    The circuit was designed by an adaptation of one I found on t'Interweb. It is a logic indicator (Hi-Lo-Pulse) which used a 4001 quad NOR gate. I rejigged it to use a 4011 quad NAND gate as I could find some of those (I have probably also got a tube of 4001's somewhere in my entropy driven storage area).
    The circuit was drawn up using Circuit Wizard (which is old and has a very basic component library) and that produced the circuit board and output Gerber and Drilling files.
    I then used CopperCAM to build a dxf from the Gerbers and then I put the dxf through the CAM process to give Gcode.
    This was all a small run as I want to do a larger board for my next(ish) project, but I will be starting with KiCAD for the circuit design.
  2. The Following User Says Thank You to cropwell For This Useful Post:
  1. BOB 3 Axis, optical isolation
    By thjremy in forum Electronic Project Building
    Last Post: 05-01-2014, 04:15 PM
  2. gerber to dxf for PCBs
    By Web Goblin in forum Computer Software
    Last Post: 26-10-2013, 08:25 PM
  3. NEW MEMBER: PCBs - desktop CNC - Hi from salisbury
    By Plod in forum New Member Introductions
    Last Post: 07-09-2013, 09:34 AM
  4. PCB Isolation Routing
    By Mad Professor in forum General Discussion
    Last Post: 16-03-2011, 09:46 PM
  5. PCB Isolation Routing
    By CHudson in forum Milling Machines, Builds & Conversions
    Last Post: 10-10-2010, 08:34 PM
