Thread: 6040Z USB connection issues
Hi, I've had my 6040 for a couple of months now, and all has been well, though it's my first foray into CNC machining so a bit of a learning curve!
That was until yesterday when I powered up for a morning of pottering and my laptop in the workshop (and home pc also, as I was later to find out) refused to recognise the cnc, throwing up this error -
"Windows has stopped this device because it has reported problems. (Code 43)
A request for the USB device descriptor failed."
I've tried all the (to me) obvious things, different usb cable, cycling the power, reinstalling the software, all to no avail. I have messaged the seller (from e-bay) but after having a read through some other threads on here I'm not over hopeful.
I don't know if anyone has any suggestions?
Many thanks
Roger
01-08-2019 #2
Hiya,
Did you manage to get this sorted out, be sure to keep any power cables away from the USB cable. This mess's with allot of machines trying to run via USB comm's and fixes the problem most of the time..Me
01-08-2019 #3
Not fixed as yet, I have ruled out interference with the usb cable by using a screened cable.
I'm still going through the support from the vendor, which is painfully slow I will say, but I have a feeling it is the usb pcb in the control box that's failed as I've tried running it with a difference pc with a fresh software install. I just need them to either send a replacement out, or tell me they won't so I can get things sorted (and upgraded :) ) myself.
Roger
01-08-2019 #4
The Following User Says Thank You to Lee Roberts For This Useful Post:
01-08-2019 #5
I had somewhat similar problem with 3dprinter. Have you tried using different usb port in laptop/computer ?
In my case windows decided to not recognise my printer on this particular port for some reason.
Also, ditch all the usb hubs if you're using any - they, for the most part, are an antenna for EM interference... Cheap ones anyway...
The Following User Says Thank You to threedee For This Useful Post:
01-08-2019 #6
01-08-2019 #7
01-08-2019 #8
Ok out of interest what Windows version are you running.
.Me
6040Z USB CNC - USB port not recognised.
By Roy in forum Chinese MachinesReplies: 9Last Post: 23-05-2021, 10:04 AM -
Which Connection ?
By manofgresley in forum Stepper & Servo MotorsReplies: 17Last Post: 13-07-2020, 01:55 PM -
CNC 6040z USB z-axis
By Sashido in forum Chinese MachinesReplies: 19Last Post: 26-03-2018, 09:46 AM -
Engraving small font - the bit digs deeper and deeper as the job goes on. 6040z
By xoneeleven in forum Chinese MachinesReplies: 46Last Post: 26-04-2016, 12:06 AM -
Or Guidance ;) Connection Name(s)
By Carlb1058 in forum Marketplace DiscussionReplies: 6Last Post: 13-07-2013, 12:48 AM
