    Hi All,
    Looking at ways to keep my cabinet wiring as tidy as possible. It seems to me that cable trays of some description are the way forward, with the aim of setting up a number of 'roads' up and down and left and right across the panel. I like the way Joe used the cable comb stuff, but not keen on covering it all up at the end. I'm also not keen on those cable spirals as getting a cable in or out seems like a nightmare.
    Next option I guess is lots of cable ties, which on my aluminium back plate would require rather a lot of holes... Also the changing the setup problem.
    I've come across this stuff (see attached image) which I quite like....
    https://www.digikey.si/product-detai...987-ND/3815064
    Any comments on that stuff?
    Am I missing a trick? Is there a better solution out there? Come on guys - let's talk OCD cabling solutions!!Click image for larger version.
    Sent from my SM-G950F using Tapatalk
    Look at CPC before RS, Farnell and Digikey unless money is no object. CPC are part of Farnell but you can often find the exact same parts cheaper at CPC.
    Cable trunking is the normal solution. https://cpc.farnell.com/c/cable-lead...-slot-trunking
    Cable tie bases are available in self adhesive or screw fixing. https://cpc.farnell.com/c/cable-lead...ble-tie-mounts
    Cable trunking that Muzzer linked to is far better for hiding excess cable, and is probably the easiest to get into if you need to change anything.
    To get neat wiring with only cable ties involves being very accurate with wire lengths, and if you do need to change anything, you normally need to cut and replace quite a few cable ties.
    To give an idea of how good trunking is, here's a couple pics from my lathes cabinet during it's retro -
  4. The Following User Says Thank You to m_c For This Useful Post:
  5. #4
    Don't forget Rapid Electronics either, they often beat CPC for some stuff even if they don't sell quite the same range, they do the Hellerman slotted conduit stuff. Just saved about£20 on my big toroidal transformer with them And I have to say that even if it doesn't lend itself to modifications, the old fashioned lacing cord has a certain niceness to it.
  6. #5
    Yes, good point. I've bought a few things from Rapid over the years.
    Lacing cord is a lost art form! I recall wiring harnesses being laced up on pinboards back in the day. Real professional examples (aerospace and defence) would even varnish the knots for added security.
  7. #6
    Slotted trunking is the best for sure. Take not you get different widths of slots, i usually use narrow slotted trunking.
  8. The Following User Says Thank You to ericks For This Useful Post:
  9. #7
    Thanks Guys, I'll take a more detailed look at the trunking - I think the narrow stuff would work well. I've just updated my build thread with my planned layout, so need to make a decision!
    Ericks, can I ask what the dimensions of your narrow trunking are? Looks about 20-30mm wide?
  10. #8
    25 w x 40 H from rs components 878-1148
  11. The Following User Says Thank You to ericks For This Useful Post:
  1. Controls Cabinet size
    By driftspin in forum Control Hardware & Systems
    Last Post: 23-11-2017, 09:34 PM
  2. FOR SALE: Free - metal cabinet
    By kingcreaky in forum Items For Sale
    Last Post: 01-01-2016, 01:33 PM
  3. Controller Cabinet
    By cropwell in forum Workshop & Equipment
    Last Post: 19-12-2015, 02:23 PM
  4. CNC Project - Desk Filing Tidy
    By Washout in forum Woodworking Project Showcase
    Last Post: 28-07-2015, 02:44 PM
  5. NEW MEMBER: JoeCNC, from Ireland, cabinet maker.
    By JoeCNC in forum New Member Introductions
    Last Post: 21-09-2013, 11:24 PM
