Page 7 of 8 FirstFirst ... 5678 LastLast
  1. #61
    Ok, bear with me as I'm still learning...
    The voltage across the resistor was 0v when off and 4.65v when on
    With the relay and resistor connected the voltage was about 1v when on and 14.7 when off (between op1 and -24v)
    With the relay disconnected it was 0v both on and off
    Sent from my SM-G920F using Tapatalk
  2. #62
    "The voltage across the resistor was 0v when off and 4.65v when on "
    is what I expect between the FET gate & source
    when the CHP 01 is switched off and on
    "With the relay and resistor connected the voltage was about 1v when on and 14.7 when off (between op1 and -24v)"
    implies the FET is leaky and not switching off completely
    when working correctly
    the FET's ON resistance should be 155 miliohms
    as the relay coil resistance is 650 ohms
    at 24V DC
    the relay coil and 27 ohm resistance should pass around 35.5 mA
    the volt drop across the FET when switched on will be
    0.155 ohm x 0.0355 A = 0.0055 V = virtually zero on a basic multimeter
    either the FET is not switched hard on so the on resistance is higher
    or your measurement includes the volt drop across your wiring and contact resistance of the connections
    "14.7 when off (between op1 and -24v)"
    when the FET is off no current should flow through the 27 ohm resistor and 650 ohm relay coil !
    to measure 14.7V at the output
    24- 14.7 must be dropped across the total 677 ohms of the relay coil and resistor
    the leakage current must be 9.3/677 =0.137 A
    so instead of the FET looking like its open circuit when off
    its more like a 107 ohm resistor !!
    "With the relay disconnected it was 0v both on and off"
    is correct
    the FET acts as a switch between the -24V/common
    and the CHP O1
    without the relay being connected
    there is nothing between the +24V and CHP O1 to pull the output up to the +24V supply
    John
  3. #63
    So you reckon the fet is borked again? I have stripped the control box back again but cant see any shorts and I'm remaking the control panel, mainly because the wire was too short but also I don't like the layout and realised it would be handy to have jog buttons for the axis as well as the hand held MPG. It also seems the perfect opportunity to start again and eliminate any issues although I've looked and can see no potential for shorts? I'm also going to add a slave axis to the machine. I am happy with it but I can see improvements and want to do it before the machine is working proper.
    So back to the Fet...my mpg is wired up with a db15 connector, I wanted to extend the wire longer so tried a male to female db15(monitor) extension cable, it didn't work and the usb controller wasn't recognised in Windows until I removed it. That is the only thing that I can think went wrong....
  4. #64
    The SVGA extension cable - there's a couple of no-connection lines in there - perhaps if those aren't wired-through it explains the inability to work. A straight-through 15-w D-type M-F should work without too much drama. Not sure what you mean by the USB controller - unless this is a Windows->pendant interface?, in which case, again, the lack of cabling may possibly explain that (not sure).
    The FET behaviour, as described, is borked.
  5. #65
    Sorry...i should of explained better. The pendant was one of these...
    https://rover.ebay.com/rover/0/0/0?m...2F163108997386
    The mpg is wired to inputs on the AXBB but the axis and jograte selectors are wired to a usb controller due to the lack of inputs on the AXBB. The svga wire was advertised as fully wired so I assumed that meant each pin was individually wired but I don't think it Is!
  6. #66
    It seems concerning that, regardless of the reason, failure of the charge pump output can result in an estop being ignored. I was planning on replicating OP's design with the charge pump output controlling my contactor. Now I'm not so sure. What are your thoughts on this?
  7. #67
    Quote Originally Posted by northbynate View Post
    1) This is the only instance I've heard of of the Charge Pump output failing.
    2) Use a Safety relay to control your contactor, with the charge pump signal as part of an E-Stop circuit controlling the safety relay. Any E-stop drops the safety relay, which drops the contactor.
    Gerry
    UCCNC 2022 Screenset
    Mach3 2010 Screenset
  8. #68
    Eh, he's back, where you been Ger not seen much of you around, hope you are keeping well and safe.
    I sent you an email some time ago about the screen set for UCCNC, did you ever make it work with the current stable version V1.2111..?
    Email: [email protected]
    Web site: www.jazzcnc.co.uk
  9. #69
    Sorry old friend, didn't see the email.
    Had a bad back earlier this year that put me out of commission for about 6 weeks. And projects at the new house have kept me incredibly busy.
    The screenset is at the top of my todo list, as soon as I can find the time. Trust me, I want it done as much as everyone else.
    Gerry
  10. #70
    The charge pump fault is now fully sorted, the only thing I can assume that caused it was a 15pin dsub extension cable which I used on my pendant, it seems not all of the 15 pins were independent, not had an issue since and repaired it with the help of this forum
    Sent from my M2003J15SC using Tapatalk
  1. Advice on a charge controller please :)
    By blackburn mark in forum General Electronics
    Last Post: 04-05-2020, 07:28 PM
  2. CNCDrive AXBB super deal?
    By driftspin in forum CNCdrive (UC100, UC300ETH)
    Last Post: 16-03-2019, 10:10 PM
  3. Not sure where the fault lays
    By terry1956 in forum Vectric
    Last Post: 20-02-2019, 11:28 AM
  4. fault testing
    By Palletlad in forum General Computing
    Last Post: 09-02-2018, 05:51 PM
  5. Jun-Air Compressor Fault
    By jamesgates1000 in forum General Discussion
    Last Post: 02-12-2017, 07:59 PM
