Thread: AXBB charge pump fault
Sorry for the late reply, so I managed to check a couple of voltages before the battery died on my volunteer again...really should remember to turn it off! It reads 9v when off and 24v when on when the relay is connected. but I had a brainwave and it works so unless you say it's a bad idea I'm going to stick with it...
The charge pump only activates the relay when the software is active and reset state is inactive, the problem was that it wouldn't then shutoff on reset or estop so I have used an opto isolated relay on another output which is the true state of reset and settable in uccnc. This means that the relay isn't active unless the software is active and reset is not. It also protects the AXBB against any other issue causing the charge pump failure..
Sent from my SM-G920F using Tapatalk
Advice on a charge controller please :)
By blackburn mark in forum General ElectronicsReplies: 23Last Post: 04-05-2020, 07:28 PM -
CNCDrive AXBB super deal?
By driftspin in forum CNCdrive (UC100, UC300ETH)Replies: 18Last Post: 16-03-2019, 10:10 PM -
Not sure where the fault lays
By terry1956 in forum VectricReplies: 5Last Post: 20-02-2019, 11:28 AM -
fault testing
By Palletlad in forum General ComputingReplies: 2Last Post: 09-02-2018, 05:51 PM -
Jun-Air Compressor Fault
By jamesgates1000 in forum General DiscussionReplies: 5Last Post: 02-12-2017, 07:59 PM
