26-05-2020 #11
Mine are medium preload (ZA) mate not high preload, rail is now straight enough for me, although huge fun (not!) there is no point chasing down +/-2um when I can deflect 300mm of 80mm box section that the rail is mounted on between uprights by 5um just by leaning on it. I listed all those example measurements to show what the system is capable of, e.g. obviously the carriage will twist on the rail when twisted, if it didn't then it wouldn't move, but in reality this is only a problem if you have a microscope bolted to the carriage as in actual use two carriages would be used mounted to a rigid plate, I was highlighting this as a source of error with how I mounted the microscope not a criticism of the hiwin system. Possibly a better (although more work) microscope fixture would be to register to the reference edge machined on the hiwin rail rather than use a carriage at all, couldn't be bothered though...
WANTED: K40 laser
By dfox1787 in forum Items WantedReplies: 0Last Post: 23-10-2018, 08:34 PM -
Newbie - Help With Laser Cutting Speed And Power - 60W Laser
By nickpscott in forum Laser Machines & BuildingReplies: 2Last Post: 11-11-2015, 10:07 PM -
FOR SALE: K40 laser not working (laser fires)
By calida in forum Items For SaleReplies: 0Last Post: 31-03-2015, 08:45 PM -
WANTED: GCc Laser Pro or Epilog Laser Cutter Machine
By Brownhills school in forum Items WantedReplies: 1Last Post: 10-05-2012, 04:30 PM -
help with cnc laser
By swinds in forum Laser Machines & BuildingReplies: 11Last Post: 09-01-2012, 10:15 PM
