Hello all,
I'm thinking about welding up a security grille for a window which looks out onto a fire-escape at my unit.
My welding experience boils down to someone once telling me "max power and thinnest rod mate". I have a small Einhell arc welder that I was given a while back, along with a mask/gloves etc. To give myself a chance of coming up with something half useful I'm considering making this from mild steel equal angle L-section (40x40x4), as it seems to me it would be reasonably straightforward to layout, clamp and get a few blobs of metal onto the bits I want to stick together.
The welding rods I have are ancient. Worth getting a few new ones? What sizes should I be considering?
I've got a reasonable amount of floorspace to work on, but no nice flat metalworking table. Am I on a hiding to nothing? Maybe go with L-section for the verticals with flat bar bolted across using max-power stud-lock?
It's one of those if they want in, they'll get in situations, the grille is more about making it inconvenient to get stuff out of the window (or forcing any potential ne'er do wells to use the window ledge precariously located over a sizeable drop...)
Wal.
02-09-2019 #2
Bake your rods at 200 for 1 hour in the oven and then test one, they'll usually be fine.
The Following User Says Thank You to magicniner For This Useful Post:
Schematic question wiring Am882 ALM Alarm, Limits and Security Relay Pilz S5 ?
By pierantoine in forum General ElectronicsReplies: 6Last Post: 01-05-2019, 02:32 PM -
Welding 5-8mm steel box-section tubes
By techcobweb in forum Welding, Brazing & EquipmentReplies: 9Last Post: 17-07-2018, 05:53 PM -
eBay Security & OpenSSL
By irving2008 in forum Marketplace DiscussionReplies: 10Last Post: 26-05-2014, 02:57 PM -
Maximum size of box section, Stacking box section, Construction Angle
By andy586 in forum Gantry/Router Machines & BuildingReplies: 0Last Post: 01-02-2013, 05:29 PM -
Aluminium box section
By martin54 in forum Gantry/Router Machines & BuildingReplies: 11Last Post: 28-10-2012, 01:13 AM
