19-09-2019 #11
Well youv'e got me thinking after your last reply. I can you the bits I have to upgrade an older machine and don't mind spending a few bob on something that runs better and I will be doing a fair amount of 2.5/3d cutting, and i'm getting old so anything that runs a bit better (quicker smoother ) i'm happy to invest in. Now the killer question is are the stepperonline kits ok (they seem to have great prices and there seems to be a 5% discount for us members) or should I look around a bit.
Andrew
19-09-2019 #14
Thanks good to know.
Andrew
20-09-2019 #16
Many of the Stepperonline drivers have 'Leadshine' written on them as well and their part numbers generally match. One of the reasons I've used them in the past is that buying a 'Stepperonline' driver from Stepperonline seems like a good way to guarantee I'm not getting a counterfeit Leadshine driver.
KitAn optimist says the glass is half full, a pessimist says the glass is half empty, an engineer says you're using the wrong sized glass.
20-09-2019 #17
Can't really say that for certain because I've had drives that look identical to Leadshine with matching numbers etc but when you open them up you can clearly see they are not made by leadshine as the quality is terrible. The counterfeiters are very clever and don't miss a trick regards Visuals and identifcations.
Unless Stepper online sell them as Leadshine drives and if they where genuine leadhsine why wouldn't they.? I wouldn't it take they are Leadshine.!Last edited by JAZZCNC; 20-09-2019 at 02:25 PM.
21-09-2019 #18
Some of the drivers have both Leadshine and Stepperonline logos. The manual says "designed by Stepperonline. Manufactured by Leadshine". I'll let you make up your own mind.
https://www.omc-stepperonline.com/di...or-dm320t.html
21-09-2019 #19
** Ignore, I'm getting Austria and Australia confused **
(Looks at watch: I'm going back to bed...)Last edited by Doddy; 21-09-2019 at 07:17 AM.
Well it looks like i'm veering towards the following configuration.
https://www.omc-stepperonline.com/1-...or-driver.html
I'm not sure which one of these to choose as the price is only a few euros more in the stronger motor.
https://www.omc-stepperonline.com/po...-s-500-36.html
I could by a new transformer to go with parts I have from my previous unregulated supply but would probably cost as much or more as the switching supply above.
The machine this lot would go on is the following which I already have.
https://www.sorotec.de/shop/Portal-m...-DIY-4862.html
Its main use would be for wood carving (guitar making ) and some light metal/plastic milling. Any opinions would be gratefully accepted. Looking at the steppersonline site I like the idea from buying from one scource. They seem to have all the extra cable extensions etc. at a reasonable price and ship from Europe which saves a lot in Duty and taxes.
Andrew
FOR SALE: Stepper Motor Power Supply From Zapp Automation
By MrBurns in forum Items For SaleReplies: 1Last Post: 02-10-2017, 04:54 PM -
Closed loop Step Servo Drive Driver 2HSS86H + 4.5N.M Motor + Encoder
By george uk in forum Motor Drivers & ControllersReplies: 20Last Post: 23-06-2014, 08:38 PM -
Testing Leadshine closed loop stepper system.
By JAZZCNC in forum Stepper & Servo MotorsReplies: 10Last Post: 13-10-2012, 05:39 PM -
Closed Loop Stepper Compared with Open Loop Stepper
By Leadshine-Erci in forum Stepper & Servo MotorsReplies: 0Last Post: 25-05-2012, 08:11 AM -
Closed Loop steppers
By funkmonkey in forum Stepper & Servo MotorsReplies: 24Last Post: 18-07-2009, 09:56 PM
