Just wondering if anyone has any knowledge of these please as I'm not getting a reply to my question from the factory.... There's an "alarm" output on the LCDA2575 driver module - does anyone know what this does in terms of function i.e. when it switches, and what is the max voltage it can switch? I have a data sheet which came with the motors, but it makes very little mention of this output.
http://www.t2cnc.hu/downloads/Lichua...r%20Manual.pdf suggests the output is simply the C/E of an optocoupler. Without knowledge of the part number of the opto you could make an educated guess based on common devices - most seem to have a Vceo of 60V upwards.
...of course you could always take one apart to check?Last edited by Doddy; 28-09-2019 at 06:28 PM.
28-09-2019 #3
I'd probably go for 24VDC and 20mA being a safe limit.
And given it's very likely a Leadshine copy/clone, and having checked some similar Leadshine drives, their usual output is 24VDC but with current limits varying between 20-80mA.Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
28-09-2019 #4
28-09-2019 #5
28-09-2019 #6
Something wrong?
I'd guess it'll depend on all what the driver is capable off, and what settings can be changed via software.
Motor/wiring problem (does the drive sense motor wiring issues?), motor following error (there's a parameter for it...).
Have you got a copy of the 'simple commissioning manual' that's mentioned below the parameter table?Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
29-09-2019 #7
I don`t know if this will help, it's a link to their product page
http://servo.xlichuan.com/prod_view....77&FId=t3:69:3
Andrew
Closed loop stepper motor kit power supply
By the great waldo in forum Motor Drivers & ControllersReplies: 19Last Post: 21-09-2019, 10:08 AM -
Closed loop steppers vs servo ?
By threedee in forum Stepper & Servo MotorsReplies: 6Last Post: 29-06-2019, 01:00 PM -
Closed loop Step Servo Drive Driver 2HSS86H + 4.5N.M Motor + Encoder
By george uk in forum Motor Drivers & ControllersReplies: 20Last Post: 23-06-2014, 08:38 PM -
Testing Leadshine closed loop stepper system.
By JAZZCNC in forum Stepper & Servo MotorsReplies: 10Last Post: 13-10-2012, 05:39 PM -
Closed Loop Stepper Compared with Open Loop Stepper
By Leadshine-Erci in forum Stepper & Servo MotorsReplies: 0Last Post: 25-05-2012, 08:11 AM
