    Hi - Anyone found a good Chinese source for 6&8mm Downcut 2 flute carbide end mills for wood routing. Alibaba and Bangood do not seme to recognise the term "downcut". Or should I be using another search term? Most grateful for your experienced advice.
    Compression bit
    May have found a possible source on Alibaba, Waiting for quotes with shipping cost. Will report back.
  5. #4
    DaveL's Avatar
    Lives in Sudbury, Suffolk, United Kingdom. Last Activity: 3 Weeks Ago Has been a member for 6-7 years. Has a total post count of 15. Received thanks 4 times, giving thanks to others 2 times.
    Compression bit
    I thought that type was up cut at the end and down cut at the top? So only useful if cutting the wood in one pass.
  6. #5
    My existing one`s are constant flue angle.
  7. #6
    Downcut bits are very useful. Can be harder to find.
    Saite_cutter store on AliExpress sells some downcut bits. Also known as left hand bits.
    Store Information
    https://s.click.aliexpress.com/e/mW45b6SG
    AU $28.64 9%OFF | 2Pcs 6x25mm Down Cutter Left hand Spiral Bit CNC Router Tool AAA Series One Flute acrylic Aluminum carving frezer endmill
    https://s.click.aliexpress.com/e/tuaU3ggC
  8. #7
    Thanks pippin88. - Just ordered from Saite_cutter store on AliExpress. Just what I was looking for. Appreciate the heads up.
  1. Where to source HHS Downcut end mills?
    By cncJim in forum General Discussion
    Last Post: 22-02-2016, 02:39 PM
  2. FOR SALE: ITC 3051 10mm 3 Flute Long Length Carbide Ali End Mills
    By Caster1 in forum Items For Sale
    Last Post: 05-01-2016, 12:21 AM
  3. WANTED: 1/8" or 3mm Single flute carbide cutters
    By craigrobbo in forum Items Wanted
    Last Post: 09-04-2013, 06:49 PM
  4. 4mm Carbide Cutters Single Flute?
    By dazza in forum Marketplace Discussion
    Last Post: 27-03-2013, 07:52 AM
  5. Single flute carbide cutters
    By Jonathan in forum Tool & Tooling Technology
    Last Post: 11-11-2011, 06:48 PM
