    Hello All
    I've got the builders in at the moment and it looks like there are going to be a few large blocks of granite 100x25x8.5cm leftover. Two of these blocks side by side would be just the right size for my sorotec compact line cnc base (https://www.sorotec.de/shop/Portal-m...-DIY-4863.html). I would assume that i'm going to either epoxy or cement the two blocks together and drill some holes for tie rods to help hold the blocks together. I would either mount this on a steel frame (to be welded together) or just lay it on the wooden bench that I have my current machine on. I would like to attach the c-line machine with bolts and washers to the granite as there are two fairly hefty aluminium extrusions running end to end. Is all of this a good idea or a waste of time as i'm mainly going to be cutting wood. I've bought finally some of the jmc 180watt servos and aparently they are quite fast, so I figured a bit of extra weight might help to keep things stable. If anyone has any comments or recomendations i'm all ears.
    cheers
    Andrew
    Chaz's Avatar
    A feasible idea. I looked at similar before going for Thor (search for my build on here) all Concrete machine. Slightly ;p larger than yours (2 ton) but similar ideas.
    Hi Chaz
    2 ton would probably have me going through the floor into my cellar. The granite blocks are pretty heavy I just hope the builders don't need them for my pathway.
    Andrew
    Chaz's Avatar
    My point was that its very feasible as an idea. No need to do 2 tons ;p
    Hi Chaz
    Yes I got that. No worries I won't be shifting granite gravestones about the place. Just out of interest does anyone on the forum any experience of drilling granite? I want to drill a few 12 mm holes through the slabs which are 25 cm wide. I've got a pneumatic hammer drill.
    Andrew
    phill05's Avatar
    Lives in Derbyshire  UK, United Kingdom. Last Activity: 14 Hours Ago Has been a member for 9-10 years. Has a total post count of 295. Received thanks 28 times, giving thanks to others 13 times.
    No you don't want Pneumatic hammer drill you need a diamond tipped core drill (PCD) and lots of water.
    Phill
    Quote Originally Posted by the great waldo View Post
    Whatever you do, don't turn hammer on it will crack it like Eggshell. While it seems rock hard Granite actually fractures very easily if handled wrong.
    Ideally, you need a Slow speed Drill with high torque and like been suggested PCD Core bit and lots n lots of clean water. Do not try cutting without Water with PCD otherwise, they just fail quickly.
    Hi All
    I think i'll give up the idea of tie rods and just epoxy or cement the two blocks into a steel welded frame. Does anyone have any ideas as to fixing the base onto the granite. I figured just drilling some holes through the granite and connecting them with bolts and t-nuts into the ali extrusion. I've attached a couple of photos of the base plate. It's machined flat the base is 20mm thick and the ali extrusion is 60mm square. All comments gratefully acceptedClick image for larger version.
ID:	26686Click image for larger version.
    cheers
    Andrew
    Chaz's Avatar
    Yep, that. Impact will cause a problem. You dont 'drill' granite, you cut it.
    I believe there must be a mechanical connection between frame and granite. Not just glue or epoxy as for me it will defeat the purpose. Best would be to be clamped somehow to bottom of the frame. But if clamped comes the danger for breaking so a thin layer of polymeric glue will help. Which again makes me doubt the whole purpose.of the operation.
    Anyway, for that exact machine polymeric glue will suffice. The kind of glue that fixes metal to metal or metal to stone. It must be sticky like sh_t, not the ones that look like silicone at the hardware store that say xxkg of force, blah blah. I dont know in Uk but in Spain you find that at a place where constructors buy their stuff. Cheaper and much better than epoxy for the purpose.
  2. CNC Router Parts.com rails, V bearings and rails blocks and more
    By adamh in forum Classified Ads, Buy, Sell & Swap
    Last Post: 25-02-2017, 01:31 AM
  3. BUILD LOG: Small workshop CNC router, steel base, planning on ATC
    By spresv in forum DIY Router Build Logs
    Last Post: 07-02-2017, 04:28 PM
  4. Supporting the machine?
    By Rogue in forum Gantry/Router Machines & Building
    Last Post: 05-09-2011, 06:02 PM
  5. Base design for new router
    By cncgreg in forum Gantry/Router Machines & Building
    Last Post: 31-08-2010, 03:35 PM
