    Hi Guys
    Has anyone purchased an expanding reamer from rgdtools, if so i am looking for feedback on the quality accuracy of same.
    Don't know why i did it but i purchased a cheap and very nasty item from ebay and it's not fit for purpose so need something a lot better.
    rgdtools item looks reasonable quality but you don't know what you are going to be sent.
    https://www.rdgtools.co.uk/acatalog/...-67966700.html
    Regards
    Mike
    Lives in East Lothian, United Kingdom. Current Activity: Viewing Forum Superstar, has done so much to help others, they deserve a medal. Has been a member for 9-10 years. Has a total post count of 2,909. Received thanks 360 times, giving thanks to others 8 times.
    I've had a couple of their smaller ones. They're ok. Certainly not high quality, but they done the jobs I needed them to do.
    What size hole are you looking to do Mike? I have a few of these in different sizes, you'd be welcome to borrow them being just ont' other side of the big hill.
  5. #4
    Hi Trevor
    34mm - it's for my Trek Pilot, removed the headset(way to tight) and when i checked it with inside calipers it was oval, so only need's a tickle(aluminum)
  6. #5
    Hi Trevor
    Just checked the ones I have and none go quite that big - sorry!
    Trevor
  7. #6
    No worries Trevor
    I have shifted to plan B/C - B make a mandrel and hand scrape. Have been trying to tidy the shed and came across my delapena hone, when i cleaned the surface rust off it, it has a range of 30mm to 36mm so that's plan C
    Regards
    Mike
  1. Dowel holes reamer or interpolation?
    By hoezap in forum Metalwork Discussion
    Last Post: 10-04-2016, 12:44 AM
  2. Expanding Copper Pipe?
    Last Post: 22-08-2015, 05:31 AM
  3. Replies: 0
    Last Post: 24-03-2015, 05:04 PM
  4. expanding foam and steel frame
    By Gytis in forum Metalwork Discussion
    Last Post: 18-08-2013, 10:35 AM
  5. WANTED: 8mm Reamer
    By Jonathan in forum Items Wanted
    Last Post: 13-04-2011, 04:43 PM
