Hi all, I have a Wadkin TC80 spindle intended for my next machine build, and beyond a marketing pamphlet I have no real information, i.e.:
*air-cooled
*7.5kW
*0-20,000rpm
*30 taper
*hydraulic tool release
Additional info I have ascertained:
*green
*heavy
I believe the machine it came off of was an Olympus.
It has a threaded hole in the front that did not have a fitting or bolt in (just taped over) which has me wondering if it's meant to have a continuous lube feed or forced air cooling. This was the standard spindle Wadkin offered at that time and not a fancier higher load/higher precision option. The spindle seems in good condition, so I don't really want to take it apart! Maintenance requirements would be great to know. Any ideas?
10-11-2019 #2
https://www.daltonswadkin.com/wp-con...0M-CONTROL.pdf
Mentions your head being cooled by an electric fan, I didn't read past that.You think that's too expensive? You're not a Model Engineer are you? :D
10-11-2019 #3
That's ace - hadn't found that doc. I'll settle in and read it properly (especially since it isn't searchable), but I see on p24 it says the TC (100, not 80) is greased for life, and doesn't mention an air supply for cooling like the LC head :)
e: ah, p30, the motor is cooled by an electric fan. I have the motor, and it's an utter monster. Not going to be used on this particular machine!Last edited by Mud; 10-11-2019 at 06:51 PM.
10-11-2019 #4
Weak your Google-Fu is Grasshopper, work on that you must! ;-)
10-11-2019 #5
I was even on that site, not sure where I failed!
10-11-2019 #6
Hmm, p94, 'compressor to give .56m^3 (5.3 cubic feet) of free air per minute at 5.3 bar. They've messed up the calc though, .56m^3 is 19.8 cubic feet. I guess it would be the higher throughput based on the similar power spindle options, might be time for a bigger compressor =/
14-11-2019 #7
eBay: FOR SALE Wadkin ..Twin head two air drills router £499 start no reserve
By Abbeyint in forum Items On eBay UKReplies: 0Last Post: 14-01-2019, 06:29 PM -
NEW MEMBER: New member seeking advice from those in the know
By jonny5 in forum New Member IntroductionsReplies: 0Last Post: 04-02-2017, 06:58 AM -
FOR SALE: Wadkin cc2000s router for sale
By CNC Graham in forum Items For SaleReplies: 1Last Post: 18-01-2016, 10:55 PM -
NEW MEMBER: Newbie seeking CNC info for guitar building
By rusty999 in forum New Member IntroductionsReplies: 4Last Post: 15-01-2016, 02:26 PM -
wadkin ux2lc/c3 with bosh cc100 controller
By george uk in forum Machine DiscussionReplies: 28Last Post: 31-01-2014, 03:25 PM
