  1. Most people often use the CNC wood routers to cut wood or acrylic. But CNC routers also can cut aluminum. Here are 3 tips to help you.
    1. Use Carbide router bits
    Carbide-coated cutters can handle the high RPMs that you need for routing aluminum. Even HSS won’t be able to handle the job. Don’t forget to tell you feed and speed calculator that your bit is carbide-coated; it will give you more RPMs.
    2. Feed and Speed Rates
    Cutting Aluminum is different with wood cutting. This is why you need to calculate your feed and speed rates. The best way to do this is to use and online feed rate calculator.
    3. Use Fewer Flutes
    You may be used to using a four-flute cutter for your woodwork, however when you’re cutting aluminum, a three-flute cutter is your maximum. This will prevent overly large chips which can cause your router to jam. The fewer the flutes, the better performance to cut aluminum. If you have 4 or more flutes, chips jam your flutes, and your bit breaks.
    From the above, if you want cut Aluminum, a specialized CNC aluminum router bits are your best choice.For example: solid carbide, single flute upcut, specially designed for aluminum or aluminum composite panels milling.
    Good luck to your work!
    Chaz's Avatar
    Lives in Ickenham, West London, United Kingdom. Last Activity: 1 Hour Ago Has been a member for 9-10 years. Has a total post count of 1,602. Received thanks 110 times, giving thanks to others 69 times.
    And lubrication.
    Alu need chips cleared at mininum, so air blast is good - the odd drop of WD40 or similar goes a long way to help keep the alu from gumming up on the cutting tool's edge. Google 'Built up Edge' or BUE.
  3. Quote Originally Posted by Chaz View Post
    And lubrication.
    That's right, to remove chips and cool the cutting tool at the same time.
    Thanks for the tips, much appreciated!
  5. I often use solid carbid single flute upcut router bits for aluminum cutting, because they can maximize the remove of chips to provent "Built up Edge".
  1. Are there any tips on re-cutting tool faces without a jig?
    By Dave_stoke in forum Tool & Tooling Technology
    Last Post: 23-10-2018, 11:14 PM
  2. Tips for cutting 1050 aluminium
    By d4cnc in forum Machine Discussion
    Last Post: 11-04-2016, 07:25 AM
  3. RFQ: Small aluminum milling/water cutting
    By Harry Hills in forum Projects, Jobs & Requests
    Last Post: 02-11-2014, 01:54 AM
  4. Best Tips for Cutting 6082 Aluminium (CNC Lathe)
    By fidia in forum Metal Finishing Techniques
    Last Post: 29-12-2013, 07:09 PM
