Thread: Spindle Grease
    I working with a china vertical mill/drill, ZX50 clone.
    The gearbox is a 4 speed unit.
    The spindle needs lubricated with grease via a nipple on the front.
    When i use the mill on it's fastest speed, which i need for steel.
    Grease starts to egress via the lower bearing and drops on to the work.
    The spindle is not getting hot - i read about 40C after it's been running for 30mins.
    (i can imagine that the inner temps of the bearing will be higher)
    Can anyone suggest -
    a) a better grease that won't drop out
    b) some other type of cure.
    thanks
    Lives in East Lothian, United Kingdom. Last Activity: 4 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has been a member for 9-10 years. Has a total post count of 2,909. Received thanks 360 times, giving thanks to others 8 times.
    Grease will always drop out to an extent, but if it's doing it excessively, then it's a sign you're putting too much grease in.
    For a spindle, I'd only be looking to inject maybe a single grease gun stroke every 50 hours of spindle run time, and I'd be injecting it slowly with the spindle running to ensure it's evenly distributed.
    Bearings don't need a lot of grease (typical bearing load is only 25-30% of available free volume), and too much grease will do damage (it can cause the balls/rollers to slide, rather than rotate).
    Many thanks for the info.
    Clearly then i have probably over lub'd it.
    What type of grease (that's available in the UK) would you suggest ?
    If you've not got anything that specifies a grease, I'd just go for a good quality lithium grease.
    Thanks.
  1. HIWIN Grease Fitting Extension
    By Raz in forum Rails, Guideways & Bearings
    Last Post: 03-05-2017, 12:07 PM
  2. Do you grease HiWin rail Sliders?
    By AndrewMawson in forum Linear & Rotary Motion
    Last Post: 09-01-2017, 04:15 PM
  3. Replies: 5
    Last Post: 29-09-2014, 02:42 PM
  4. Replies: 0
    Last Post: 13-11-2013, 07:50 PM
  5. Ballnut Lubrication / Grease
    By Mad Professor in forum Lead Screws, Nuts & Supports
    Last Post: 18-07-2012, 08:08 PM
