09-01-2020 #10
If you have access to a milling machine I would definitely put them top and bottom. If you want to mount them on the face and keep the same rail separation then you need a deeper gantry, if you use 160x80 profile for the gantry then the Y rail centres will *only* be 120mm apart (distance between outermost slots), the same profile with top-bottom mounts gets you ~180mm centres. On my last machine I used 160mm ali box section for the gantry and with face mounting close to the edges got around 140mm centres.
BUILD LOG: Design stage - All steel - 1200x750x110 - aluminium capable (hopefully)
By oliv49 in forum DIY Router Build LogsReplies: 3Last Post: 08-06-2018, 01:18 PM -
welding steel base or just getting aluminium extrusion
By reefy86 in forum Gantry/Router Machines & BuildingReplies: 200Last Post: 15-01-2018, 08:55 AM -
BUILD LOG: Steel Frame, Aluminium Hybrid Design Thread
By f1sy in forum DIY Router Build LogsReplies: 0Last Post: 23-02-2016, 10:04 AM -
Steel vs Aluminium
By gavztheouch in forum Metalwork DiscussionReplies: 4Last Post: 26-05-2014, 10:11 PM
