Thread: Manual Control of Z Axis
11-12-2019 #1
Hello folks.
My first post here so first off, hope this is posted in the right part of the forum.
I'm reaching out for help here due to my limited knowledge of all things cnc, hoping somebody here might be able to point me in the direction of components that might help.
I'm a carpenter and joiner and recently built myself a small router sled for flattening slabs, constructed from 20mm slot 6 profile and using a Mafell FM1000 milling motor. I mount the motor in an old plunge base with a 43mm collar and it works great. Nothing cnc level but ideal for what I'm using it for.
Having done a few slabs now, the plunge router base is proving a tad annoying sometimes. With no micro adjust and depth stops at too large increments for surfacing bits, I have to lower my eyeline to view the workpiece and bit, then try and plunge and tighten whilst crouched below the router. This often takes me 3 or so attempts for each pass. It works but not ideal.
I'm thinking a small linear actuator rather than the plunge base would be ideal. This is where I need your help. Although you can buy these ready to go, motor and all for the z axis, I'm struggling for info on a more manual means of motor control. At it's most basic, what I'd be after is simple, manual up/down motor control - an up button and a down button. Is this a possibility with the stepper motors that come with the actuator kits and could you help me with what I need to make this possible?
Look forward to any suggestions.
Stew
Shanghai Shi Shun 3040 4 axis corrupt user manual
By Seafax in forum Chinese MachinesReplies: 5Last Post: 26-02-2017, 10:04 PM -
[HELP] 6 Axis B.O.B with spindle control
By birchy in forum General DiscussionReplies: 7Last Post: 02-10-2014, 12:15 AM -
5-axis Breakout Includes Hand-Held Control Port & 3,4,5-axis Postion-Display Port
By LoveLearn in forum General ElectronicsReplies: 12Last Post: 25-05-2013, 12:41 AM -
NEW MEMBER: I am going to build a 3 axis servo control
By markey1979 in forum New Member IntroductionsReplies: 8Last Post: 16-11-2011, 12:53 AM -
Leadwell/ Fanuc Om control manual
By fastcarl in forum Machine DiscussionReplies: 0Last Post: 26-06-2011, 11:09 AM
