05-02-2020 #131
Yes, Theory is great. However at the DIY level theory and reality often part company early on in the build process at which point reality often comes back and smacks you fully in the face.
I find if you have patience use Common sense along with doing the Duediligence like what you are doing now. Then provided you choose the right design for your needs and take care when building it that you will always end up with a machine to be proud of that won't disappoint.
Keep asking the questions like what you are doing and it will eventually make more sense, it won't make complete sense until you started the build, which at some point you will say "Aghh I get what Boyan was saying now." .!!
05-02-2020 #132
If you want the best machine then you must bite the bullet and go with Profiled linear rails. If not then you are wasting your time worrying about things like COG or plate thickness because Boyan is 100% correct that the machine is only as good as the weakest link and round rails will by far be the weakest link no matter which axis you put them on.!
05-02-2020 #133
05-02-2020 #134
Someone hasn't yet gotten into the theory of their motor calcs yet! More mass on the Z axis means everything has more to accelerate! NIGHTMARE!!
Personally I think we should all just make them out of bamboo and some twine, powered by hamsters, and tamagotchis as control interfaces to just be done with it :)
05-02-2020 #135
Interesting point! But you still have to considered the torque drop when hamsters get hungry and be sure to size the running wheel according to your choice of hamster, too small and your hamster will simply get stuck and start doing loops...Other than that you should be sweet
05-02-2020 #136
For a first time hobby builder I think clone rail is fine, BST automation on Alixpress are a good place to start.
If I was sinking thousands into a frame, decent spindle, etc I'd buy original and I already have original Hiwin on most my machine just one axis is clone.
I can tell you Hiwin's are definitely smoother than cheap clone rail before I fitted them but in practice on the router working you can't tell the difference. With 1610 ballscrews one step in 0.05mm so that's really what limits your resolution. Never consider microstepping actual resolution it's something very different. On a Mill clone rail probably makes a lot less sense.
If I was working it for cash 10 hours day I would definitely go original Hiwin.Last edited by Desertboy; 24-02-2020 at 09:51 AM.
It was because of you and Boyan I never used the SBR 25 rail I have and bought Hiwin's and clone hiwin's.
One day I might use them for a plasma cutter, I did buy new bearings for them they do feel "nice" but very glad I went with rail instead.
One really annoying thing about them the mounts are 46mm apart.http://www.mycncuk.com/threads/10880...60cm-work-area My first CNC build WIP 120cm*80cm
24-02-2020 #140
Academic research on CAM CAD software/ Help please
By lorenzo0572 in forum CAD & CAM SoftwareReplies: 3Last Post: 03-05-2014, 11:08 AM
