Page 1 of 13 12311 ... LastLast
    ...and now I seem to have myself a new hobby trying to put together my first ever cnc from scratch! I have no prior experience with cnc’s, but I’ve been looking at getting one for some while now. Mostly for various wood projects I’ve got going on from time to time, but also hoping to get my kids involved and interested in industrial design (I.e. to better understand what actually goes into making things).
    Now, having spent countless nights looking at different kits online and ploughing through forums I’ve come to realise that all the kits within my budget come with compromises, many of which I wouldn’t be prepared to pay the asking price for. Luckily, I stumbled upon mycncuk which, to my mind, seems to offer the most helpful and on point advice of any cnc related forum I’ve visited. Actually, it’s the active members here that have (unknowingly) pushed me over the edge and got me worryingly excited about this.
    Which brings me to what I’m doing here. I’ve lurked around the forum and stolen a bunch of great ideas which, in turn, has yielded a concrete plan of what I’ll get myself into. For anyone kind enough to drop me some critique, I’ll be posting my initial iterations in the build log thread (I hope that’s the correct one) and hopefully I’ll get started soon enough!
    Other than that, cheers to all of you who actively and constructively share your views with us less experienced- I’ve already learnt a ton!
  2. Welcome and best of luck with your build.
    Cheers! I can't seem to get my design pictures uploaded (they're resized to requirements and I've tried three different OS) but will post my plans as soon as I get it to work.
    Quote Originally Posted by Juranovich View Post
    What format are you using? Also you might need to make a couple more posts.
    I am sure Lee (forum owner) will pop up and sort it for you
    I think they were png (I'm using the free version of shapr3d for rough sketching and it only allows for stl exports and screenshots).
    Welcome to the forum. You'll find plenty of help and advice here.
    You have to make a minimum number of posts (10 I think) before you can upload pictures. have a look at the forum rules.
    Kit
    I’ve been operating my machine for a couple of years and if there is one thing I would tell anyone who is designing a CNC... think scenarios where things go wrong. How easy will it be to fix or adjust your machine.
    For instance my Ox is great when it works... but when the belts come loose I have to disassemble a lot of the carriage if the Y axis comes loose and don’t get me stared on the holes for the tension adjust on the long rails.
    You see you actually have to remove two inner wheel stacks just to get to the bolts that hold the stepper motor in place. It’s just bad design imho. Maintenance tasks like belt tensioning should be simple to do.
    So imaging you crash your machine (don’t worry, we all do it). Your carriage is now skewed... how would you realign it to the frame.... I solved that for me by hitting the emergency stop, moving the carriage to one end where I have aligned two end stops... I push the carriage gently against the stops and the release the E-Stop... the motors come online and all I have to do then is run a homing cycle.
    Oh yeah, you will need to install limit switches so you can run homing cycles. Definitely makes life easier.
    Oh and these are just suggestions from CNC noob... I’m still learning every day... but loving every minute.
    Just to be clear for the benefit of new users.
    limit switches and homing switches do two different things. Although a homing switch can be setup at one end to act as both. ie it is a homing switch when first run (homed) then the software changes it to a limit switch.
    Limit switches are nearly at the end of travel on each axis to stop the machine from hitting the hard stops
    And soft limits are there to stop you accidentally crashing the machine due to any one of a dozen easy mistakes. But they only work only AFTER you have used the homing switches to tell the machine where it is.
    That's not quite correct actually. Soft limits will work without a home switch by just hitting Home all, after which home will be where ever the machine happens to be parked. However, it's not advised because then you still crash the machine into the ends. But if your going to fit just home switches then you may as well make them move with the axis and have them double up as Homes and limits.
  1. Academic research on CAM CAD software/ Help please
    By lorenzo0572 in forum CAD & CAM Software
    Last Post: 03-05-2014, 11:08 AM
