With some cutting imminent (once I get the AXBB sorted!) I'm thinking I ought to get going on a cutter cooling/chip blowing setup. I have various air supply options available with varying degrees of noisyness, just wondering how much airflow is needed please? I'm thinkinh of making something a bit like Boyan's setup: thanks.
24-01-2020 #2
I think it will depend a lot on your setup. I find pushing around 3 PSI seems to work well enough for me, squirting air / ethanol mix.
24-01-2020 #3
Any idea how much volume you're using please (cfm or m3/hr)?? Adjusting the pressure is pretty easy, but if the compressor won't do the volume you're stuffed!
24-01-2020 #4
Nope. I moved to a screw compressor and a 200L tank setup so that I could compress and not be concerned about it.
24-01-2020 #5
OK, no worries, thanks for the info on the pressure - a lot less than I was guessing!
24-01-2020 #6
Ill double check but effectively my 'guess' is as much pressure as is need to help the lubricant but mostly to clear chips. Anymore feels like a waste.
24-01-2020 #7
I have done the same type of setup as boyan with the filter housing etc. Im running it at 15psi with thin cutting oil and that works well. I have an 8cfm compressor with 100 litre tank that keeps up fine. The thinner the cooling medium the less pressure you will need to move it.
24-01-2020 #8
25-01-2020 #9
Complete control
25-01-2020 #10
Ethanol mist for cutting aluminium
By matt-b2 in forum Swarf & Chip ManagementReplies: 60Last Post: 15-08-2021, 11:05 AM -
Mist Coolant Project
By magicniner in forum Swarf & Chip ManagementReplies: 10Last Post: 06-11-2018, 09:39 PM -
Schneider Altivar 320 wiring / setup help needed
By TadasM in forum Spindles & Drive MotorsReplies: 31Last Post: 21-10-2016, 07:43 AM -
WANTED: Mist lubrication system
By badgerman in forum Items WantedReplies: 9Last Post: 21-08-2014, 12:28 AM -
i7 Water cooling system
By Jonathan in forum Metalwork Project ShowcaseReplies: 19Last Post: 01-01-2012, 06:27 PM
