Thread: Converting an axis to belt drive
I want to convert my bottom axis Axis, dual motor to belt drive.
I have 2 nema 23 4nm motors to fit on this axis over doubling the torque.
https://www.cnc4you.co.uk/Stepper-Mo...H401-03-Nema23
I have 2 questions
What T5 pulley should I use?
What T5 belt?
Will this Belt do?
https://www.cnc4you.co.uk/T5-Pulleys...ming-Belt-20mm
And are these pulleys even suitable?
https://www.cnc4you.co.uk/T5-Pulleys...ith-grubscrews
I see grubscrew and think 4nm is a lot of torque to hold on 4 grubscrews.http://www.mycncuk.com/threads/10880...60cm-work-area My first CNC build WIP 120cm*80cm
18-02-2020 #2
The Following User Says Thank You to Doddy For This Useful Post:
18-02-2020 #3I have 2 questions
What T5 belt?
https://www.beltingonline.com/timing-pulleys-bars-272/..Clive
18-02-2020 #4http://www.mycncuk.com/threads/10880...60cm-work-area My first CNC build WIP 120cm*80cm
18-02-2020 #5
I would personally run the smallest gear possible as there us less weight to turn
The Following User Says Thank You to johngoodrich For This Useful Post:
18-02-2020 #6
Wide and small?
18-02-2020 #7
First, convert to a belt drive from what.?
HTD is the belt to use. Pulley size will depend on how you do it and the resolution you want. Don't think because it's a 5mm pitch belt that's the actual pitch or linear movement you'll get because it's not. The diameter of the pulley x Pi is the actual pitch you'll end up with. So depending on how it's done and pully size you could need a gear ratio to give the resolution you need.!
18-02-2020 #8
Coupling driven, I'm upgrading the motors and would like to undersling the motors more for space than anything else, 1610 ballscrews.
I was going to run on a 1:1 ratio I was hoping it was a case of 2 matching pulley's just different ID mounts.
I'll get some photo's when it's light it becomes obvious in the day light.
I'm happy with 0.05mm resolution per step the 1610 gives me.Last edited by Desertboy; 18-02-2020 at 09:00 PM.
18-02-2020 #9
I found a (bad) pic of the motor mounts, I ditched those flexible couplings as soon as I actually tried to use the machine. Having cutting problem, they were the first thing I replaced.
And one from when I was still building it, I have it on a catering table now and connected to a DDCSV.
you can see the mounts better.
I want to flip the motor mount upside down, then mount the motor under the machine. The motor mount has 4 mounting holes which align with 4590 aluminium track. I can slide the mount left and right to tension the belt before bolting down with T nuts.
Motor mount is 10mm thick aluminium plate NOT ecocast.
I have the machine in a van so undersling the motors will create me a little more space and protect the motors.
I have bolted an extra piece of 4590 behind the machine to space it off the ply.
That groove isn't from the machine but it does line up perfectly LOL.Last edited by Desertboy; 18-02-2020 at 08:16 PM.
18-02-2020 #10
Ok I misunderstood. Thought you were converting completely to belt drive not just wanting to connect motors. Forget what I said that doesn't apply in this case.
Still use HTD thou.
6m X axis Rack and pinion or belt drive?
By charlieuk in forum Rack & Pinion SystemsReplies: 6Last Post: 02-07-2020, 01:22 AM -
BUILD LOG: belt drive to ballscrew drive changeover advice required
By marbles in forum DIY Router Build LogsReplies: 4Last Post: 14-02-2020, 02:14 AM -
Belt drive on a router
By John S in forum Rails, Guideways & BearingsReplies: 23Last Post: 10-09-2012, 09:39 PM -
any one know where to get a belt drive convertion for x2
By Scott in forum Sieg Milling MachinesReplies: 15Last Post: 27-09-2010, 08:44 PM -
Re: Standard Drive Belt Size ?
By HS93 in forum Belt Drive, Pulleys & TimingReplies: 0Last Post: 18-05-2009, 03:30 PM
