    I want to convert my bottom axis Axis, dual motor to belt drive.
    I have 2 nema 23 4nm motors to fit on this axis over doubling the torque.
    https://www.cnc4you.co.uk/Stepper-Mo...H401-03-Nema23
    I have 2 questions
    What T5 pulley should I use?
    What T5 belt?
    Will this Belt do?
    https://www.cnc4you.co.uk/T5-Pulleys...ming-Belt-20mm
    And are these pulleys even suitable?
    https://www.cnc4you.co.uk/T5-Pulleys...ith-grubscrews
    I see grubscrew and think 4nm is a lot of torque to hold on 4 grubscrews.
    I have 2 questions
    What T5 belt?
    Unhelpful answer, but why T5 and not e.g. HTD? or GT2?, improved backlash and better high speed performance (random google).
  3. The Following User Says Thank You to Doddy For This Useful Post:
    Lives in Marple Stockport, United Kingdom. Last Activity: 19 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has been a member for 9-10 years. Has a total post count of 3,333. Received thanks 618 times, giving thanks to others 78 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    I have 2 questions
    What T5 belt?
    HTD 5 would be a better belt and pulley
    https://www.beltingonline.com/timing-pulleys-bars-272/
  5. The Following User Says Thank You to Clive S For This Useful Post:
  6. #4
    Does size matter?
    Thinking how many teeth and how wide the belt is. Guessing widest belt is better but pulley diameter not so important.
    I have 4nm Nema 23's I want to run 1:1 gear ratio.
  7. #5
    I would personally run the smallest gear possible as there us less weight to turn
  8. The Following User Says Thank You to johngoodrich For This Useful Post:
  9. #6
    Wide and small?
  10. #7
    First, convert to a belt drive from what.?
    HTD is the belt to use. Pulley size will depend on how you do it and the resolution you want. Don't think because it's a 5mm pitch belt that's the actual pitch or linear movement you'll get because it's not. The diameter of the pulley x Pi is the actual pitch you'll end up with. So depending on how it's done and pully size you could need a gear ratio to give the resolution you need.!
  11. The Following User Says Thank You to JAZZCNC For This Useful Post:
  12. #8
    Coupling driven, I'm upgrading the motors and would like to undersling the motors more for space than anything else, 1610 ballscrews.
    I was going to run on a 1:1 ratio I was hoping it was a case of 2 matching pulley's just different ID mounts.
    I'll get some photo's when it's light it becomes obvious in the day light.
    I'm happy with 0.05mm resolution per step the 1610 gives me.
  13. #9
    I found a (bad) pic of the motor mounts, I ditched those flexible couplings as soon as I actually tried to use the machine. Having cutting problem, they were the first thing I replaced.
    And one from when I was still building it, I have it on a catering table now and connected to a DDCSV.
Name:	motor mount.JPG
ID:	27417 you can see the mounts better.
    I want to flip the motor mount upside down, then mount the motor under the machine. The motor mount has 4 mounting holes which align with 4590 aluminium track. I can slide the mount left and right to tension the belt before bolting down with T nuts.
    Motor mount is 10mm thick aluminium plate NOT ecocast.
    I have the machine in a van so undersling the motors will create me a little more space and protect the motors.
    I have bolted an extra piece of 4590 behind the machine to space it off the ply.
    That groove isn't from the machine but it does line up perfectly LOL.
  14. #10
    Would something like this be suitable with the right bore for the Nema's and Ballscrew?
    https://www.beltingonline.com/16-too...16-5m-25f-7792
  1. 6m X axis Rack and pinion or belt drive?
    By charlieuk in forum Rack & Pinion Systems
    Last Post: 02-07-2020, 01:22 AM
  2. BUILD LOG: belt drive to ballscrew drive changeover advice required
    By marbles in forum DIY Router Build Logs
    Last Post: 14-02-2020, 02:14 AM
  3. Belt drive on a router
    By John S in forum Rails, Guideways & Bearings
    Last Post: 10-09-2012, 09:39 PM
  4. any one know where to get a belt drive convertion for x2
    By Scott in forum Sieg Milling Machines
    Last Post: 27-09-2010, 08:44 PM
  5. Re: Standard Drive Belt Size ?
    By HS93 in forum Belt Drive, Pulleys & Timing
    Last Post: 18-05-2009, 03:30 PM
