Thread: Joe90's BIG RAT Build.
27-06-2020 #36
Cast plate tends to be mostly tooling plate and is very flat with a shiny machined surface or ground surface in most cases. It's easily identified from a rolled plate which tends to have a dull finish and is rarely flat.
Also, Cast plate is heat-treated and annealed to relieve stress as part of the casting process so it's very stable and cuts completely different to rolled plate. The chips that come off are like little balls rather than stringy chips because of the grain structure which is much finer, it also doesn't have hard n soft spots as the rolled plate does.
I buy mine locally and the grade is 5083. You can buy Cast plate from Aluminium warehouse and Ecocast is their trade name for cast plate but I believe it's 5083 grade.
You will also find it under the name Mic5 or Mic6 which is basically 5083 or 6082 grade. 6 series cast plate isn't so common and much more expensive usually and to be honest I find little difference between the two in machining terms, obviously, if you need the 6 series properties then that's different but I find 5 series more than good enough for any CNC use.
I buy mine locally and it's 5083-use common sense, if you lack it, there is no software to help that.
Email: [email protected]
Web site: www.jazzcnc.co.uk
By Karl in forum DIY Router Build LogsReplies: 12Last Post: 08-02-2017, 08:03 PM
