Thread: NordicCNC's build log
06-03-2020 #31
Hello, looks good! Interesting with the rotating ball nut. I understand it so that you have placed the fixed bearing on the spindle plate and then the other ball screw end is lose. Does it stick up in the air or what does it look like when the Z-axis is fully retracted?
Anyway I have to say that your advice is quite contradicting compared to the advice I have received from others. I am not saying you are wrong but I try to stay open minded!
06-03-2020 #32
I did say I was throwing a spanner in the works, I know it's not a conventional way of making this and yes contradicting to what has gone before but it works and works really well it is compact, less weight, and the machine cuts very well, just wanted to give you an idea of what works without going to far.
The screw is bolted tight to bottom of spindle plate (no bearing) and screw goes up with plate, attached is an image when I first put it together.
Phill
06-03-2020 #33
Oh my! You have quite some Z-axis travel height there. I can see that the screw will be sticking out in the air when Z-axis is fully retracted (at the top end position). I think you rarely use that Z-height or are you doing some custom jobs?
Looks like the gantry clearance is around 100-120mm, am I right? It would also be interesting seeing a video of its performance in aluminium/steel!
You have definitely given me something to consider, thanks for that.
06-03-2020 #34
You can't be serious.? You are using a rotating ball-nut on the Z-axis and you think he's going overboard with things.!
That design with the screw sticking up 400-500mm above the z-axis when at the top is just a crazy, pointless design and overly complicated for its application. Rotating ball-nuts are great on longer axis but for a Z-axis they will make no difference because the screw is so short that whipping or inertia don't factor into the equation which is the only reason to use a rotating nut, even with servo's which spin much faster than steppers.
Also regards your intended design with the L-shape Gantry that is all mixed up as well. Your design wastes Gantry clearance height because using the middle slot on the profile and misses the whole point of the "L" design. The point being the L shape is so most of the cutting forces are directed into the horizontal piece placed at the bottom where forces are highest.
06-03-2020 #35
JAZZ, I think the way you have installed the pneumatic actuators and the Z-axis cover design is great! The whole machine design is phenomenal.. I hope you don't me taking ideas and copying some features from it?
I've removed my spacer plates now and added a machining to both the rear and the front plate to make room for the bearing and ball screw nut housing. This reduced the overhang by 15mm! It also reduced the total weight a few kg's. Thanks for the tip!Last edited by NordicCnc; 06-03-2020 at 10:38 PM.
06-03-2020 #36
06-03-2020 #37
07-03-2020 #38
Great and you have explained it very well!
By the way I have now decided that I will not use the 180W JMC servo motors that I bought in advance. I've come to realize that they are holding me back by limiting the weight of he machine. It was an expensive learning lesson but now I know that I should always wait with buying any components until the design is completed.
I've contacted the supplier and they might be willing to accept a return and I would pay a little more to get the 400W JMC servo motors in change (https://www.aliexpress.com/item/4000067490526.html). In case they don't accept the return for some reason then I have already found another use case for them, so that problem is solved - no money lost. If I then still buy the 400W JMC's, I don't know, I will have to check what you and the others here think. I saw that delta servo's were recommended as well and it was also mentioned that larger than 400W would probably be good?
Anyway the motor power issue is now out of the way and I have the money to spend on new and way more powerful motors!
So now having solved the motor power issue, do I still keep the Z-axis weight as low as possible or should I start trying to beef it up? The covers I will design to be structural, taking ideas from your machines JAZZ. The Z-axis front plate I am not so sure if I can improve much since it is already very stiff. Perhaps the Z-axis design is good as light weight and I can just stop worrying if the motor power will be enough to handle the heavy ATC spindle!
10-03-2020 #39
Short update on the Z-axis design! You might notice that the design is heavily influenced by JAZZCNC's build's (e.g. the cover and L-shape gantry), although still very different and definitely no where near his quality!
Modifications:
- Based on feedback I have now removed the stiffening ribs from the front plate. The reason is that since the front plate is directly mounted to the X-axis bearings with literally no overhang, the stiffening ribs would add nothing but weight. Instead a 3mm aluminium sheet is bent and welded, forming a cover that is structural while also protecting the components and cables from chips.
- Removed the linear rail spacer plates and added machining to both the rear and front plate, to make room for the BK12/BF12 bearings and the 1605 ball screw.
- 180W servo motors are no longer a constraint. Now I am thinking about getting Delta 400W servo motors. On the Z-axis I plan to use one with brake: https://www.aliexpress.com/item/3267...23d152a8ZJcwMZ. On the X- and Y-axis I plan to use ones without brakes: https://www.aliexpress.com/item/32671356516.html?spm. All axis with still be geared 2:1, to limit the ball screw maximum speed to 1500rpm.
- Modified the top bearing plate to account for BK15/BK15 bearings and 2010 ball screw on the X-axis (in design process).
- Preliminary positioning of proximity switches. The X-axis will only need one, but for the Z-axis I might need 2 if I can't find a location which I can use for both homing/top limit switch as well as bottom limit switch.
- New Z-axis weights are 45kg (total) and 25kg (moving).
Here is the Z-axis mounted on the draft X-axis design, made with 120x80 Item profiles (I will post a more detailed X-axis design description later):
10-03-2020 #40Preliminary positioning of proximity switches. The X-axis will only need one, but for the Z-axis I might need 2 if I can't find a location which I can use for both homing/top limit switch as well as bottom limit switch...Clive
By Karl in forum DIY Router Build LogsReplies: 12Last Post: 08-02-2017, 08:03 PM
