20-12-2009 #1
hello, is there any way of running more than one stepper motor from a single signal/driver??
20-12-2009 #2
You'll either end up drawing twice the current, give each motor half the driver's current, or give half the voltage to each motor depending on the configuration and the driver.
Wiring in parallel would try to get twice the current drawn through the driver - if it's a constant current driver, then this would effectively split the current to each motor. If your driver is capable of feeding more current, then you could configure your driver to do that.
Wiring in series would end up with the same current, but half the voltage (with everything that entails).
20-12-2009 #3
While in theory it will work, it is not a good idea.
1) drivers are not designed to run two motor so will void the warranty
2) any anti resonance circuitry in the driver would be useless.
3) The current would be very high and would need a larger driver, so would most likely be better to get two smaller drivers.Visit Us: www.automationshop.co.uk
Driving me insane
By Bush Flyer in forum Motor Drivers & ControllersReplies: 17Last Post: 14-04-2014, 03:55 PM -
Belt Driving your leadscrews !
By Lee Roberts in forum Lead Screws, Nuts & SupportsReplies: 11Last Post: 05-02-2011, 09:14 AM -
How to connect my driver to my steppers
By speedhound in forum Gantry/Router Machines & BuildingReplies: 9Last Post: 16-01-2011, 02:52 PM -
Driving floating end (ballscrew)
By blackburn mark in forum Lead Screws, Nuts & SupportsReplies: 16Last Post: 11-09-2010, 11:55 AM -
FOR SALE: Stepper Driver. 4x Steppers. Supported Rails.
By Conan257 in forum Items For SaleReplies: 3Last Post: 24-10-2009, 07:31 PM
