I wondered if anyone had recommendations for a well priced crimping tool, suitable for use with bootlace crimps?
There seem to be simple versions around, which essentially squash the crimp tube with shaped but fixed formers. And then there are more sophisticated ones, which form the crimp tube into a square or hexagon, using moving formers. Obviously the latter are a lot more expensive, but are they worthwhile? Or for the volume of crimping the typical hobby CNC-er might do, would the basic ones suffice?
Any thoughts or pointers most welcome!
Graeme
13-03-2020 #2
I bought this one:
https://www.ebay.co.uk/itm/352833747135
after being pointed in the right direction by Clive (he has something similar).
Used it a fair bit putting my new control box together, works really well.
Wal.
13-03-2020 #3
13-03-2020 #4
Pfff bootlace ferrules are the bain of my life and I've wasted days chasing wiring issues because of them.! . .
13-03-2020 #5
Mmmm, didn't realise my question would be controversial!
Why do they cause you problems, Jazz?
Thanks Wal and Clive for your input - that's really useful. Now I just need to know if I should be using them....
14-03-2020 #6
Nah not controversial really just differing opinions and experiences.
Mostly for the reasons Doddy mentioned, poor crimps and poorly crimped. But I'm not just talking about Ferrels I've fitted, ( I don't use them anymore, I prefer stranded wires when using terminal blocks) I'm talking about on older machines and esp on Chinese machines when they have been poorly fitted or cheap nasty crimps. Often because of bad crimping or just age they work lose but wire doesn't always pull or fall out and you get false contacts etc, (3 days I wasted tracking a fault down due to a poor crimp.! . . But that's another story.!) Yes I know this can happen with stranded wire breaking but I find it's easier to see and track down.
The reason I don't use them anymore is for several reasons based on my own experience using them on lots of machines.
#1 To crimp correctly and test they are time-consuming
#2 Expense, good quality ones are not cheap and neither is the tool.
#3 When poorly crimped they are difficult to track down.
#4 I lose and drop more of the bastards than I fit.!
#5 I'm lazy..
It's a personal thing so don't stress over it, either way will work.! . . . But don't come back in 6mths time saying got a fault because you know I'll just say TOLD YOU SO. .
14-03-2020 #7
It's not really controversial. Should you use them? EU wiring regulations require that stranded wire is retained if the mating terminal does not provide this (so that includes screw and cage terminals. The problem with stranded wire is that on installation, and also in use under vibration you can get strands moving from the contact area resulting in poor or failed electrical contact. Tinned stranded wire is not an acceptable solution.
Outside of the EU regulations can be more relaxed. And for a home builder it's not an issue at all, though good practise can still be followed.
There is an issue with commercial manufacture that you should use the ferrule manufacturers approved tooling which can come with significant $$ costs for the home builder, so the Amazon specials (one of which I have) are unlikely to cut the mustard from a certification perspective. You have to find a happy medium for which you're happy that the cost balances against your own requirement.
I do have a cheap one that gives a two-jaw compression pattern, I'm tempted to get a 4-jaw square-form tool similar to Wal's, but recognise that the 4-jaw is likely to give problems cold-welding to fine-gauge wires (as Clive reports) - ironically the (poorer) 2-jaw is more predictable in this regard.
If Jazz and others have problems with ferrules I'd be checking the crimp tool and the ferrules used to understand where the failure stems from. I wouldn't exclude poor quality / inappropriate mating terminal blocks particularly from the Far East.
(Anecdote: As an electrical apprentice back in the good ol' days, and spending a summer placement in an Instrument Laboratory testing calibrated crimp tools and resultant crimped assemblies I can attest to the mechanical strength of a good crimped terminal and the resulting predictable low resistance contact, and to the tedium of spending a summer testing these... but this was in an industry where the operating shake-and-bake environment had rather more significance than a CNC machine)
EDIT: What should possibly be considered is whether panel wiring should use solid-core cable where possible. I could understand and support that assertion, though I carry so little solid-core that I'd ignore that advice myself.Last edited by Doddy; 14-03-2020 at 08:57 AM.
14-03-2020 #8
Likewise I have a problem with crimping fork terminals, (or spade, etc) and I don't trust any of the crimpers I have tried, I always give the wire a good pull, and invariably some, in fact, most, come loose.
So I now remove the insulating coloured plastic with pliers and crimp just the one half of the round metal with small cutter pliers in two places (with just enough pressure to crimp - otherwise you would cut the metal!) and then with small flat pliers I press and fold the other half of the metal over the first half. Difficult to explain, I know. After doing that, I slide the insulating plastic back in position.
Anyway, after discarding dozens of crimps done with the crimping tool, I now prefer to do it by hand, 100 per cent success and secure and it doesn't take long.
14-03-2020 #9
Great info there, guys - as ever, it is good to be able to go into a new process with some insight from others, whether that be positive or negative.
My take from all this is that the key is getting a decent crimp. And it also sounds like that is quite feasible with any of the tools - even the basic two jaw types. But maybe each crimp requires a careful inspection to be sure it worked ok. And whilst that is acceptable for us hobby users, it doesn't work so well commercially. And maybe that is where the more expensive branded tools come in.
So as ever, you make your choice. I'm not in the market for a silly money crimping tool, so I'll likely go for one of Wal's/Clive's recommendations. I have a control box to wire shortly - and likely more in the future - hence I thought I might as well make the jump now.
If it works well, I may report back. But if I have problems, I'll likely just go quiet, after Jazz's promise!
Graeme
14-03-2020 #10
This may come back to bite me on the arse, but I've had no problems with my crimper (- that sounds weird...) Just spent a couple of minutes trying to pull a ferrule off and it's on solid as - not budging...
I have a little '+ & -' adjustment wheel on the crimper that appears to set the level of squeeze - if I'm doing thin wires I'll ramp it up (+) and dial it back for the fatter gauges. Pff, I dunno - like I say, it appears to work a treat, but I'm a noob with very little experience..!
Wal.
NEW MEMBER: Machine recommendations
By Cncnewbie in forum New Member IntroductionsReplies: 6Last Post: 22-05-2021, 09:38 PM -
Any recommendations for a DTI please?
By Voicecoil in forum General DiscussionReplies: 1Last Post: 03-12-2018, 12:59 PM -
UK Supplier Recommendations for BT30 tool holders
By camhguh in forum Tool & Tooling TechnologyReplies: 8Last Post: 17-02-2017, 10:25 AM -
7 Colours 6 Values Bootlace Ferrules Kit
By Lee Roberts in forum Items For SaleReplies: 16Last Post: 05-06-2016, 02:38 PM -
views on bootlace ferrules?
By routercnc in forum General ElectronicsReplies: 7Last Post: 07-02-2015, 12:16 PM
