Thread: Retro-Fit Denford Router
Never done this before, logging progress onlie as well as the retro-fit.
So I have a Denford Router that has been converted to Mach3 by previous owner.Since I have had it I have already fitted a Chinese 2.2kw water cooled spindle so now it is time to upgrade the control which at the moment is Mach3 with a cheap BOB and the original Baldor drive board.
After getting some great advice off theis forum the new setup will be UCCNC with an AXBB-E Motion controller and Stepper Motor Driver 6.0A, 80V CNC Microstepping CW806 stepper drivers powered with a hoe made PSU using a Airlink 500VA 230v to 2x45v toroidal transformer. The intention is to use as much of the existing electronics where possible.
Here is the control cabinet just after I started:
15-04-2020 #2
Progress after day 1. I have identified the X,Y & Z stepper cables and will identify the home switches later. My plan of attack is to disconnect and remove everythng that isn't going to be needed like the old Danford spindle controller. Hopefully I will just be left with the original power/relay/fuses (I did say hopefully)
Things are going well with the cabinet looking a lot emptier.
Bending down inside a cabnet is not as easy as it was (you'll know when you get older) so some work has been done on the new control gear to give my back a rest
15-04-2020 #3
The attachments are not working
15-04-2020 #4
15-04-2020 #5
15-04-2020 #6
[QUOTE=Clive S;116028]They are now. but would be nice to have them rotated[/QUOTE
how do I do that, they are the right way up on the PC?
17-04-2020 #7
19-04-2020 #8
Flashing lights and no magic smoke.
I need to source some bigger terminals for the transformer to rectifier connection and a twisted ethernet cable as going via a hub is having issues connecting.
The UCCNC software imported the Mach3 setting but although it let me set the E-stop and probe pins and port it doesn't save the home pin or port (looks like I will be googling tonight)
Lessons learned today.
You can lose a screwdriver several times in a small space.
DIN rail connectors are not the easiest thing to get the end of a wire in.
An electricl schematic is no substitute for a wiring diagram for an amateur.
19-04-2020 #9
One good reason why some of us use crimp-on ferrules! They make putting wires into DIN connectors and other difficult-to-reach places a whole lot easier, and less chance of odd strands shorting out on adjacent terminals. I used them for the first time wiring my own control box and I'm a convert. Other people reckon they don't make as reliable a long-term connection but I'm not sure I could have managed to get wires into all the connectors in my box without them.
19-04-2020 #10
Best UK company to do a servo retro fit on Syil X5
By Benja in forum Milling Machines, Builds & ConversionsReplies: 2Last Post: 11-07-2018, 11:47 PM -
Triac - old version, retro fitted servos
By Benja in forum Classified Ads, Buy, Sell & SwapReplies: 2Last Post: 23-02-2018, 12:28 PM -
Denford router - Brushed router too brushless spindle - Help and advice please
By Tom B in forum Brushless Spindles & MotorsReplies: 4Last Post: 16-05-2016, 09:13 AM -
Retro fitting an old Dahlgren engraver.
By millietess in forum Motor Drivers & ControllersReplies: 0Last Post: 29-11-2014, 09:41 PM -
Stay with Gearbox or retro fit DC motor etc;
By manofgresley in forum Linear & Rotary MotionReplies: 1Last Post: 06-04-2013, 05:17 PM
