    Hi chaps, don’t you just get sick to death of Chinese crap with no manuals. Ok, I have three wires coming out of the huanyang inverter.these are U,V,W. CAn anyone please let me know which terminals on the spindle electric block, these go into. Click image for larger version.
ID:	28013 please see picture. Thanks, Michael
    Just an update, I found some information on the web. And wired the U,V,W terminals to the spindle block pins.1,2,3. Start the power and the spindle sounds like it is spinning up, but it’s not turning at all. Any ideas out there
    Do not power up the motor unless you sure that you connected it properly and set drive parameters correctly :)
    DaveL's Avatar
    Lives in Sudbury, Suffolk, United Kingdom. Last Activity: 4 Weeks Ago Has been a member for 6-7 years. Has a total post count of 15. Received thanks 4 times, giving thanks to others 2 times.
    Do you have a multimeter that can measure resistance?
    You should be able to check between pairs of contacts, hopefully you will find 3 pairs with a similar resistance, the 3 coils of the motor. One of the other contacts could of an earth, which could be connected to the body of the motor.
    AndyUK's Avatar
    Lives in Southampton, United Kingdom. Last Activity: 4 Weeks Ago Has been a member for 6-7 years. Has a total post count of 469. Received thanks 100 times, giving thanks to others 43 times. Referred 1 members to the community.
    Quote Originally Posted by DaveL View Post
    In which case you really don't want to wire one of the phases to the spindle body... that would be a great way to get a very nasty shock.
    OP - Take care.
  1. Wire EDM machine
    By Neale in forum Other Machines & Building
    Last Post: 05-11-2018, 09:31 AM
  2. Wire diagram
    By Raymond in forum Lathes, Lathe Rebuilding & Conversions
    Last Post: 11-06-2014, 06:24 PM
  3. CNC hot wire cutter
    By Nstocks in forum Machine Discussion
    Last Post: 22-05-2014, 07:54 PM
  4. How to Wire this Sensor
    Last Post: 26-11-2013, 05:09 PM
  5. Wire.. Oh why so many types....
    By BedlamRik in forum General Electronics
    Last Post: 05-01-2013, 01:05 AM
