Thread: Z Problem
09-11-2009 #1
Hi new to this so please bear with me.
have a problem when cutting multi passes on the z.
all runs fine and then it will add 10mm plunge on the z.
getting use to g code cant see a problem there
please any reson why it would do this
thanks Airwolf:feedback:
09-11-2009 #2
10-11-2009 #3
Hi This is The G code
Code:(BEGIN PREDATOR NC HEADER) (MACH_FILE=3AXVMILL_MM.MCH) (MTOOL T1 S1 D6.3 H6.5 DIAM_OFFSET 1 = 3.15) (SBOX X0. Y0. Z-18. L994.484 W400.144 H0.) (END PREDATOR NC HEADER) % O100 (PROGRAM NUMBER) (PROGRAM NAME - LOUIE TABLECURVE.NC) (POST - MACH 3 ROUTER METRIC) (DATE - MON. 11/09/2009) (TIME - 07:23AM) N01 G21 G40 G49 G54 G80 G90 G91.1 N02 G53 (JOB 1 CONTOUR) (FEATURE PROFILE) N03 T1 N04 S2525 M03 N05 G00 G90 G54 Z5. X994.484 Y1.198 N07 G01 Z-4.5 F256.6032 N08 Y70.854 F500.3763 N09 X975.392 Y140.349 N10 X946.875 Y200.947 N11 X907.91 Y256.916 N12 X858.208 Y305.156 N13 X802.507 Y344.733 N14 X739.259 Y374.54 N15 X672.688 Y393.56 N16 X618.548 Y400.144 N17 X586.813 Y399.238 N18 X530.816 Y393.494 N19 X461.609 Y375.635 N20 X403.473 Y347.919 N21 X341.625 Y305.894 N22 X292.465 Y256.734 N23 X254.658 Y203.671 N24 X224.21 Y140.006 N25 X204.466 Y71.801 N26 Y.416 N27 G00 Z5. N28 X994.484 Y1.198 N29 Z.5 (JOB 1 CONTOUR) (FEATURE PROFILE) N30 S2525 N31 X994.484 Y1.198 N32 G01 Z-9. F256.6032 N33 Y70.854 F500.3763 N34 X975.392 Y140.349 N35 X946.875 Y200.947 N36 X907.91 Y256.916 N37 X858.208 Y305.156 N38 X802.507 Y344.733 N39 X739.259 Y374.54 N40 X672.688 Y393.56 N41 X618.548 Y400.144 N42 X586.813 Y399.238 N43 X530.816 Y393.494 N44 X461.609 Y375.635 N45 X403.473 Y347.919 N46 X341.625 Y305.894 N47 X292.465 Y256.734 N48 X254.658 Y203.671 N49 X224.21 Y140.006 N50 X204.466 Y71.801 N51 Y.416 N52 G00 Z5. N53 X994.484 Y1.198 N54 Z-4. (JOB 1 CONTOUR) (FEATURE PROFILE) N55 S2525 N56 X994.484 Y1.198 N57 G01 Z-13.5 F256.6032 N58 Y70.854 F500.3763 N59 X975.392 Y140.349 N60 X946.875 Y200.947 N61 X907.91 Y256.916 N62 X858.208 Y305.156 N63 X802.507 Y344.733 N64 X739.259 Y374.54 N65 X672.688 Y393.56 N66 X618.548 Y400.144 N67 X586.813 Y399.238 N68 X530.816 Y393.494 N69 X461.609 Y375.635 N70 X403.473 Y347.919 N71 X341.625 Y305.894 N72 X292.465 Y256.734 N73 X254.658 Y203.671 N74 X224.21 Y140.006 N75 X204.466 Y71.801 N76 Y.416 N77 G00 Z5. N78 X994.484 Y1.198 N79 Z-8.5 (JOB 1 CONTOUR) (FEATURE PROFILE) N80 S2525 N81 X994.484 Y1.198 N82 G01 Z-18. F256.6032 N83 Y70.854 F500.3763 N84 X975.392 Y140.349 N85 X946.875 Y200.947 N86 X907.91 Y256.916 N87 X858.208 Y305.156 N88 X802.507 Y344.733 N89 X739.259 Y374.54 N90 X672.688 Y393.56 N91 X618.548 Y400.144 N92 X586.813 Y399.238 N93 X530.816 Y393.494 N94 X461.609 Y375.635 N95 X403.473 Y347.919 N96 X341.625 Y305.894 N97 X292.465 Y256.734 N98 X254.658 Y203.671 N99 X224.21 Y140.006 N100 X204.466 Y71.801 N101 Y.416 N102 G00 Z5. N103 M05 N104 G53 Z50. N105 G53 X0. Y0. N106 M02 (END OF PROGRAM) N107 M30 %
Last edited by Lee Roberts; 11-11-2009 at 02:01 AM. Reason: Placed his gcode into tags.
Powertran VFD problem
By phill05 in forum Spindles & Drive MotorsReplies: 7Last Post: 29-10-2013, 07:59 PM -
Bearing fit problem
By paulus.v in forum Linear & Rotary MotionReplies: 7Last Post: 09-10-2013, 09:54 AM -
Problem with X
By gorbo in forum General DiscussionReplies: 17Last Post: 24-02-2011, 05:33 AM -
z axis problem on rye ma 1500 with a bosch cc100
By rickybabe in forum Rye CNC RoutersReplies: 3Last Post: 28-04-2010, 09:04 AM -
Problem with calibration
By m.marino in forum Gantry/Router Machines & BuildingReplies: 5Last Post: 22-04-2010, 04:19 PM
