Page 4 of 14 FirstFirst ... 23456 ... LastLast
  1. #31
    This is explained corect by Peter.
    The flat that I use is first checked on a granite measuring block as you can see on the previous picture 's.
    Here is the latest series of photographs of the scraping.
    As you can see the final scraping is for the oil .
    I've scraped the sides of the Y axis but I forgot to take photographs.
    I wish the best for the new year to everyone that you have a creative year.
    Kind regards ,
    Andre
ID:	1388   Click image for larger version.
ID:	1389   Click image for larger version.
ID:	1390   Click image for larger version.
  2. #32
    Since everybody likes photos,here some pictures of the changes to the knee.
    Important is a good arrangement of the workpiece and a proper alignment so the error margin is as small as possible.
    It is important that you make a plan off attack .
    A strategy of how to start your project which consists at first of making a list that says what all needs to be adjusted and which alterations you want.
ID:	1392   Click image for larger version.
ID:	1393   Click image for larger version.
ID:	1394   Click image for larger version.
ID:	1395   Click image for larger version.
ID:	1396   Click image for larger version.
ID:	1397   Click image for larger version.
ID:	1398   Click image for larger version.
  3. #33
    In this case I want some adjustments related to central lubrication system because original grease was used instead of oil to lubricate so therefore
    it is necessary to drill new channels.
    Also to support the Y ballscrew it is necessary to make an opening where a custom bearinghousing can be mounted.
    Also a balancing weight is needed to support the weight of the knee to compensate otherwise I think the servo motor will not long survive the abuse.
ID:	1400   Click image for larger version.
ID:	1401   Click image for larger version.
ID:	1402   Click image for larger version.
ID:	1403   Click image for larger version.
ID:	1404   Click image for larger version.
ID:	1405   Click image for larger version.
ID:	1406   Click image for larger version.
ID:	1407   Click image for larger version.
  4. #34
    The last week was one of heavy lifting the maneuvering of the heavy component was not always easy if you are working alone two hands are not always enough
    and you must improvise.
    The next thing I do is start going to make the smaller components.
    Do You want pictures of the parts alone, or also the making of the parts themselves ?
    Kind regards ,
    Andre
ID:	1409   Click image for larger version.
ID:	1410   Click image for larger version.
ID:	1411   Click image for larger version.
ID:	1412   Click image for larger version.
ID:	1413   Click image for larger version.
  5. #35
    Hello everyone,
    Today I started machining the first part of three which the servo motor of the Z axis will hold.
    The first part is the base plate which directly on the knee is assembled.
    I prepared the pocket to fit the base plate previously.
    containing 6 M8 holes and two 8H7 holes for clevis pins to keep everything in place.
    I used a piece of aluminum quality 1.6082 T6 ( T6 is the treatment the aluminum received) so it is good for milling.
    First I put my vise on the table and aligned it properly .
    Than i machined it in the proper order in this case first the bigger side
    than I turned it around and put a cylindrical piece between the part and the vise so it will be square and did one small side.
    Then I did the facemilling on the second small face also with the cylindrical piece.
    and after that the second bigger plane and OK.
    After that i took an endmill and did the milling off one side .
ID:	1418   Click image for larger version.
ID:	1419   Click image for larger version.
ID:	1420   Click image for larger version.
ID:	1421   Click image for larger version.
  6. #36
    I want the edges to be round so i am going to mill some rounds on the corners.
    The first thing i will do is make two small center drill holes on the positions off the center off the radius.
    But first i have to choose a workpiece zero point.
    There are several ways to find an edge you can use a piece of paper ,a cylindrical piece off metal which is painted with a color marker ,, or a wiggler center finder is a tool used in the spindle of a machine such as a mill. The device is used to accurately determine edges or markings and therefore the center of a workpiece or a previously machined feature during the set-up phase of a machining operation.There are also several 3d edge finders mechanical and elektronic.Here are a few .
ID:	1423   Click image for larger version.
ID:	1424   Click image for larger version.
ID:	1425   Click image for larger version.
ID:	1426   Click image for larger version.
ID:	1427   Click image for larger version.
  7. #37
    Now I will locate the center off my milling table and make it zero X and Y on the DRO because I can use my table as a rotary table (so if you have a rotary table the result is the same) if it is done I put my workpiece on top of it and use pointed pin to find the previous drilled center holes.
    If done so see that the vise is fixed .
    I use a roughmill first and later an enmill for finish the rounds.
ID:	1429   Click image for larger version.
  8. #38
    After the rounds I rough out the slab and finished whit an end mill later I made two chamfers by rotating the table 45 degrees.
    After that I drilled the holes and OK
    Thats all for today.
ID:	1431   Click image for larger version.
ID:	1432   Click image for larger version.
ID:	1433   Click image for larger version.
ID:	1434   Click image for larger version.
ID:	1435   Click image for larger version.
ID:	1436   Click image for larger version.
ID:	1437   Click image for larger version.
  9. #39
    Hi Andre
    great pictures,i greatly admire the job you are doing to your mill:clap:
    you must have put in a lot of man hours!!
    just a quick question when scraping the slides how did you get both sides to match as you would not have been able to sit your straight edge directly onto them because of the dove tail?
    might seem like a silly question but i was just curious as i am no enginner
    Tom
  10. #40
    Hello Tom,
    first of all there are no stupid questions.
    We started with the support for the table .
    As you can see on the pictures first I have the upper surface with a facemill straightened and next the dove tail .
    I started scraping this section and than after the milling on the table I checked how far off straight she was on my granite measurement block (1,5m*1m)
    as you can see with a dialtester and after scraping and measuring I used the support it self to check for flatness until within the tolerance.
    Is that what you wanted to know?
    Kind regards ,
    Andre
ID:	1450   Click image for larger version.
ID:	1451   Click image for larger version.
ID:	1452   Click image for larger version.
ID:	1453   Click image for larger version.
ID:	1454   Click image for larger version.
  1. CONVERSION: Archdale Conversion
    By meyerga00 in forum Conversion Build Logs
    Last Post: 17-06-2012, 09:24 AM
  2. Mill conversion to cnc
    By wolsey in forum General Discussion
    Last Post: 15-08-2011, 11:07 PM
  3. Bridgeport Conversion
  4. Sieg sx2 conversion kit
    By Goldigger in forum Milling Machines, Builds & Conversions
    Last Post: 24-04-2011, 07:42 PM
  5. A little conversion tool
    By D-man in forum Computer Software
    Last Post: 18-12-2010, 04:58 PM
