    Wal's Avatar
    Lives in Stockport, United Kingdom. Last Activity: 4 Weeks Ago Has been a member for 9-10 years. Has a total post count of 491. Received thanks 71 times, giving thanks to others 29 times.
    Hello all,
    Had a load of long-lozenge shaped construction ply off-cuts left over from a recent job and thought it a shame to bin 'em. Picked up some 14mm (10mm ID) tube for the bushings from a scrap bin and had a bit of threaded rod lying about. The two L brackets were an old (sawn in half) motor mount I'd made myself for a bit of a project that never worked as expected and has since been disassembled. Only thing I need more of are the empty dessert jars... Shouldn't be a problem.
    Anyway, here it is:
ID:	28988 Click image for larger version.
ID:	28990 Click image for larger version.
ID:	28989 Click image for larger version.
    Wal.
    EDIT: Nuts are torqued up to give a bit of resistance and stud-locked into position, each level moves independently.
  2. The Following User Says Thank You to Wal For This Useful Post:
  3. #2
    Creme brulee?
    Wal's Avatar
    Indeed. And not only... Salted Caramel Cheesecake too...
  5. #4
    Aha I'll have to look out for those!
  6. #5
    Wal's Avatar
    Hurry, limited edition...Click image for larger version.
  7. #6
    Lives in Plymouth, United Kingdom. Last Activity: 13 Hours Ago Has been a member for 9-10 years. Has a total post count of 1,730. Received thanks 295 times, giving thanks to others 11 times.
    With a bladder like mine, you'll need bigger pots...
  8. #7
    Wal's Avatar
    They're ramekins, you animal...
  9. #8
    No way would I ramekins mine in that tiny pot...
    Email: [email protected]
    Web site: www.jazzcnc.co.uk
  10. #9
    Minor mods needed to cope with the shiraz as well as the salmon pinwheels but I like the concept of being able to tuck it under the bench and keep the swarf out of your hors d'oeuvres.
  11. #10
    Well Wal,
    You have inspired me to organise my small parts storage (Drawer 1 of 3).
    Rest of the bench is still a shitheap though...
    This is part of an ongoing project which started in March...
    Note the use of the soft-focus filter to give an extra dimension of dreaminess (I must clean the lens on my phone)
    Rob
  1. Saving For CNC
    By Fozz84 in forum Chinese Machines
    Last Post: 30-08-2016, 10:21 AM
  2. A4 Reference Chart Storage
    By magicniner in forum Workshop & Equipment
    Last Post: 29-06-2016, 05:54 PM
  3. Saving machine settings between sessions
    By Neale in forum Machine Control Software
    Last Post: 07-05-2014, 08:17 PM
  4. Mach3 digitizing wizard not saving file
    By dudz in forum Probing, Digitizing & Scaning
    Last Post: 08-09-2013, 09:48 PM
  5. bending metal -saving lives
    By BillTodd in forum General Discussion
    Last Post: 13-10-2009, 06:08 PM
