There's nothing any more dangerous about a toroidal PSU versus any other PSU of similar voltage and wattage. However, I think you might be slightly confused though - I'd expect that you'd be buying the servo with a matching servo driver. Looking at lt Lichuan 60's on Aliexpress - that's certainly a common bundle. In which case - check the datasheet, but the servo drivers would likely be 220VAC mains driven, and in which case you wouldn't need the high power, high voltage toroidal PSU. Or maybe I'm too tired and I've missed a point in your post?
I will definitely be buying a matching driver(amplifier) from lichuan. I really have no idea about powering electronics, I probably don't even know the questions I should ask. What's confusing me is that the servo's are AC and the recommended PSU outputs in DC.
