    Hey,
    because now I miss access to a CNC milling machine (in my previous job I had access to an "Ergwind MFG 4025" milling machine), I want to build my own CNC milling machine.
    I want to use it mainly as a hobby and amateur (not 8 hours a day), to work mainly with aluminum - cutting emblems for classic cars, making custom details / parts, such as this air filter housing, etc.
    https://www.instagram.com/p/1Objgml4py/
    The cutters used are mainly diameter 1-3mm maybe 5-6 (with small depression)
    Working area about 600 x 400 x 150 - but maybe a little bigger
    Before I start buying parts and putting them together, I have a question for you which solution will be the best?
    I am thinking of a solution similar to this:
    https://www.instagram.com/p/B4iQNFeqwFu/
    My assumptions are:
    - lower base frame - aluminium extrusion profiles 80x80 Item or similar
    - gantry profile - 80x160
    - side support of the gantry made of aluminum plate (20mm?)
    - one or two? ball screw 1605 for X axis
    - spindle 2.2kW chinees
    - hiwin linear rails
    At the moment I have 4 hiwin qhh15ca Z0
    whether to use them for the Y and Z axis, and for the X axis buy qhh20?
    Or use them for X and Y and for Z buy qhh15ca ZA ?
    That's it for the moment, if I remember something else, I will write it.
    Are these my plans ok or should I change my assumptions?
    Thanks for your help and best regards
  1. Router losing steps. Solution needed. Will this help?
    By cncbobuk in forum Chinese Machines
    Last Post: 27-12-2017, 03:40 AM
  2. FOR SALE: For Sale - Small D/Top CNC/Mach3 router
    By Leadhead in forum Items For Sale
    Last Post: 04-07-2016, 02:35 PM
  3. BUILD LOG: Small CNC Router
    By Plantationpark in forum DIY Router Build Logs
    Last Post: 22-02-2016, 12:22 AM
  4. Small Gantry Router
    By mike os in forum Gantry/Router Machines & Building
    Last Post: 08-01-2015, 07:02 PM
  5. WANTED: Wanted small cnc router
    By lukecnc2012 in forum Items Wanted
    Last Post: 10-10-2014, 06:51 PM
