Page 2 of 2 FirstFirst 12
    6082-T6 if fine as well the stuff you have is awful to cut
    Agreed. Also I’ve generally seen thin sheet as 1050 and thick sheet as 5000,6000,7000 series. I have not seen thin sheet at 5,6,7000 series but I might not be looking in the right places. There could be a technical reason for the alloys produced like that or just that thin stuff is often bent and fabricated.
    I've ordered some 6061 - let us see what that is like to cut when it arrives....
    Wal's Avatar
    Lives in Stockport, United Kingdom. Last Activity: 4 Weeks Ago Has been a member for 9-10 years. Has a total post count of 491. Received thanks 71 times, giving thanks to others 29 times.
    I've got a few sheets of 6082T6 in 1mm/2mm/3mm thicknesses - not common as thin sheet, but it's out there. As ever, the problem is buying in small quantities - I bought a few sheets in each thickness to make it worth the suppliers while - Metalweb on that occasion. I use Smiths nowadays.
    2014 and 7075 also machine well - bit pricier, though...
    5 grade works, but I'd choose 6082 over it any day.
    Wal.
  4. The Following User Says Thank You to Wal For This Useful Post:
  5. #14
    I had not considered brass, which is a more expensive material, but I wonder if that would be a better metal for an inexperienced operator to start with?
  6. #15
    Wal's Avatar
    C360 Brass (Free Cutting/Machining) is the benchmark for ease of machining...
    https://www.metalsupermarkets.co.uk/...ass/brass-360/
    It's a joy to use - CZ120, CZ121 etc. readily available, but like you say, not cheap...
    If I were you, I'd stick with getting the right parameter sussed out for ali - you may as well. I've still got my beginner melty bits in a box of scrap somewhere, you need to break a few eggs to make that omelette. Get crackin'.
    Wal.
  7. #16
    also what type of cutters are you using? are they polished flutes or are they coated? uncoated polished flutes are best for aluminium. Also with a 1mm cutter i would be looking to spin it as fast as possible, on my machine i would run that flat out at 24000rpm and about 100mm/min with 0.5 depth of cut.
  8. #17
    Quote Originally Posted by johngoodrich View Post
    I'm using cheap Chinese two-flutes. Advertised as carbide, but who knows...?
    The calculators say run at about 10,000, and the earlier suggestions that I was melting the Ali make me think that this may be too fast. I can run up to about 18,000 on my system.
    I have not tried running much above 20mm/min, since I am concerned about breaking the cutter (which is why they are cheap!). I have been cutting at about 0.5mm - perhaps if I cut at 0.2mm I can try running a faster feed....
  1. Poor man's T-track
    Last Post: 04-10-2019, 01:42 AM
  2. Poor cut quality
    By DMW in forum Tool & Tooling Technology
    Last Post: 22-10-2018, 11:06 PM
  3. BZT - A Poor Quality Machine
    By fidia in forum Gantry/Router Machines & Building
    Last Post: 23-09-2015, 10:43 PM
  4. Poor start to New Year
    By russell in forum General Computing
    Last Post: 04-01-2013, 02:24 PM
  5. Cutting wooden letters and shapes - purchase help for a newbie please!
    By kemo_2002 in forum Marketplace Discussion
    Last Post: 29-08-2012, 11:40 PM
