24-01-2021 #1
Hi Everyone I would like to introduce myself - I am Jonathan, based in Northamptonshire and I am currently in the market for a CnC router - I think!
I understand steppers and how to drive them and that's about it.
I am not sure if I can make this reality or if what I am after will be out of my budget/justification of the amount of intended use
I have recently been in "sponge" mode soaking up as much info as I can - the pandemic might have worked in my favour as it's stopped any knee jerk purchases from eBay etc that could have turned out to be a poorly thought out approach.
So I want to mill modelling foam to create the type of thing in the picture below which can then be used top vreate a GRP plug - I think I will need a 4th axis?
Ideally I would like to be able to cut from a solid block of foam approx 1500m x 500mm x 400mm (Z) I realise this probably not possibole without ££££££ and I think I may have to cut in sections and join them together.
Last night I pretty much gave up on the idea as too complex, as my brain was addled with info and machines costing £££££ , too far out of my comfort zone - so I am posting here for any pointers that might be able to put a smile back on my face and a dent in my wallet.
I have £1.5-2k to spend
I was tempted to buy a cheapo £100'ish China derived machine which would end up in the skip just to get on learning the software (Mach 3) and g code - would this make sense - any suggestions as to ideal platform - or any other suggestions to get on with the learning wqould be much appreciated.
many thanks for all and advice in advance
Regards
Jonathan
NEW MEMBER: Hello form Create space London
By KevinK in forum New Member IntroductionsReplies: 0Last Post: 13-09-2015, 02:30 PM -
How to Create Simple 3D Model
By Earle in forum CAD & CAM SoftwareReplies: 2Last Post: 30-07-2015, 09:34 AM -
Create dxf file.
By Tanky_Turk in forum CAD & CAM SoftwareReplies: 6Last Post: 10-02-2014, 10:03 PM -
NEW MEMBER: Another Hello from Hull
By nibbles in forum New Member IntroductionsReplies: 1Last Post: 07-11-2010, 09:01 PM -
NEW MEMBER: Ello from Hull
By Kai in forum New Member IntroductionsReplies: 1Last Post: 31-10-2010, 06:40 PM
