    I have been reading the information and guides on this site to help me clime the steep learning curve of CNC conversion. I have a Amadeal AMD25LV mill that I wish to convert to CNC on 3 axis the M/c will mainly be used for making clock parts in brass and some light steel machining. Using the very good tutorial and spreadsheet by irving2008 I have calculated I need 3.1nm stepper drives for the x and y for the vertical Z axis I am considering using again a 3.1 stepper with a 2:1 timing belt to give more torque and also position the drive out of the way of any counter balance that I may need to fit, I plan to use the original lead screws but change the nuts to control backlash.
    Firstly does the above sound sensible?
    Secondly I have seen stepper motor and drive kits at CNC4YOU at what looks a good price! are they a good buy?, if not can someone recommend a good motor/control combination.
    Lastly all my computers run on Ubuntu which is a Linux operating system so naturally I am looking at LinuxCNC, any comments please.
    Thanks in anticipation
    Steve
    Steven The motors from cnc4you are good quality but the drives are better bought else where something like Leadshine AM882 or M860 I would think carefully about using the existing screws if they are of the acme type. Ball screws can be got from Chai at linearmotionbearings2008.
    If you are used to Linux Linuxcnc is very good. ..Clive
    Last edited by Clive S; 20-07-2014 at 08:20 AM. Reason: corrected as Irving pointed out. Thanks
    Wal's Avatar
    Lives in Stockport, United Kingdom. Last Activity: 3 Weeks Ago Has been a member for 9-10 years. Has a total post count of 491. Received thanks 71 times, giving thanks to others 29 times.
    A big +1. Clive introduced me to Linux CNC and even as a newbie user, I can tell you it's great - the only thing that may have the unlikely potential to frustrate you is that the current distribution is built on 10.4. Not sure about when a new release is due.
    Wal.
  5. The Following User Says Thank You to Wal For This Useful Post:
  6. #4
    Lives in Plymouth, United Kingdom. Last Activity: 25 Minutes Ago Has been a member for 9-10 years. Has a total post count of 1,729. Received thanks 295 times, giving thanks to others 11 times.
    I've been using LinuxCNC for a couple of years and haven't had any issues with it. Might change to Mach3 for my new machine, but that's because I'm thinking of using an Ethernet motion controller, and I might also use twin X motors. LinuxCNC does not support either of these things. I doubt that you will need the higher pulse rates or twin X motors for a milling machine so it's a good option.
  7. The Following User Says Thank You to Neale For This Useful Post:
  8. #5
    Steven The motors from cnc4you are good quality but the drives are better bought else where something like Leadshine AM882 or M860 I would think carefully about using the existing screws if they are of the acme type. Ball screws can be got from Chai at linermotion2008 .
    I have looked for "linermotion2008" on the web and cant find them! are they still in business?
  9. Try "linearmotionbearings2008"
  10. #7
    Thanks Irving I have corrected my post ..Clive
  1. CONVERSION: Amadeal AMA 25LV Mill to CNC
    By Sherlock Holmes in forum Conversion Build Logs
    Last Post: 07-01-2020, 11:29 AM
  2. CONVERSION: Harrison Mill Conversion
    By m_c in forum Conversion Build Logs
    Last Post: 27-10-2016, 07:15 PM
  3. CONVERSION: Sx3 mill conversion
    By dazza in forum Conversion Build Logs
    Last Post: 29-04-2014, 10:23 AM
  4. CNC Fusion Kit for Warco mini mill / Amadeal XJ12-300
    By rnr107 in forum Gantry/Router Machines & Building
    Last Post: 03-07-2012, 01:18 PM
  5. Mill conversion to cnc
    By wolsey in forum General Discussion
    Last Post: 15-08-2011, 11:07 PM
