    Just before we get the scrap man in to top up our tea fund i thought i would see if anyone thinks there may be something of use to them, mind you its damm heavy stuff :-)
    malc
    depronman's Avatar
    Lives in St Annes on the Sea, United Kingdom. Last Activity: 44 Minutes Ago Has been a member for 5-6 years. Has a total post count of 159. Received thanks 19 times, giving thanks to others 6 times.
    What are the circuit breakers
    Are they suitable for a cnc cabinet?
    The e stops look handy as well
    Also what is the transfer in the front of the first picture any voltages on it
    Cheers. Paul
    depronman's Avatar
    Are the black motors with the ally on the end stepper motors and is the ally part some form of gearbox ?
    If so I’d be interested in a few of them
    Had a look online and can’t find any info on them
    Hi Paul
    E-stops will do perfect for this type of work
    I will take some better pictures for you tomorrow so you can make a better call than me for the other bits
    And yes that is a gearbox on the end of the stepper motor and no i dont know the ratio :-D
    malc
    depronman's Avatar
    Excellent. Cheers. Paul
    What is the frame size of the steppers Bernie?
    And how long before they go in the skip. I know we are locked down but I can go out to fix appliances, so If your works heaters need attention I could visit.
    And i am not fluent in itallian Paul but could Giri (on the plate ) indicate the ratio
    depronman's Avatar
    That’s a good call john
    In which case these would be excellent for a project that I have in mind
    Paul
    I can put anything aside for as long as needed to save the scrap man :-)
    So frame size, i am really sorry but not sure i know which bit to measure.
    only 4 of these
    malc
    Hi Malc
    The nema flange designation would be the size of the square flange in inches so looking at the ones with gearbox I am guessing from your caliper Nema 34 and I would like a couple of those if possible .
    https://www.kollmorgen.com/en-us/dev...ma-frame-size/
    Difficult to see if the ones which you say you have only four are bigger or smaller but the square size of the flange would tell us .
    E stops? yes please
    Breakers? yes please
    Are there any distinct drivers or are they incorporated into the machines boards?
    Anything there that looks like a power supply? I certainly see transformers both toroidal and conventional.
    Am thinking that the it would be good to have the opportunity to have what in Cumbria we would call a "ratch".
    For those who do not understand our lovely dialect I am thinking of a rummage amongst the contents of the heap ,
  1. 12V air pressure system to clear chips?
    By RobC in forum General Electronics
    Last Post: 25-04-2019, 11:10 PM
  2. SOLD: Clear out time!
    Last Post: 24-03-2018, 11:41 AM
  3. Replies: 1
    Last Post: 18-07-2017, 08:54 AM
  4. FOR SALE: Connectors, Heat sinks and other parts clear out....
    Last Post: 09-02-2011, 06:00 PM
  5. FOR SALE: 48V Power Supply - The clear-out continues
    Last Post: 09-02-2011, 02:14 PM
